Ana içeriğe geç
LG V10 Headphone Jack Replacement
Neye ihtiyacın var
  1. LG V10 Headphone Jack Replacement, Battery: adım 1, 1 resimden 1.
    • Wedge the flat end of the plastic spudger, or the tip of your finger, in between the back cover and the LG V10’s charging port.
    • If using a spudger, it should not be in the charging port, but between the metal lining of the charging port and the back cover.
    • Carefully lift up on the spudger or with your finger so that the back cover pops up. The rest of the back cover should easily come off by sliding a finger or spudger under the back cover and around the sides.
  2. LG V10 Headphone Jack Replacement: adım 2, 2 resimden 1. LG V10 Headphone Jack Replacement: adım 2, 2 resimden 2.
    • There’s an impression next to the battery for the user to use their finger to pry the battery out; pry the battery out using your finger or the flat end of the spudger.
  3. LG V10 Headphone Jack Replacement, Motherboard: adım 3, 3 resimden 1. LG V10 Headphone Jack Replacement, Motherboard: adım 3, 3 resimden 2. LG V10 Headphone Jack Replacement, Motherboard: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using a screwdriver with a J000 Phillips bit, remove the fourteen 3.175 mm screws.
    • Using a plastic opening tool, pry part of the panel up starting from the sides of the battery slot.
    • Use plastic tweezers to release the rest of the panel from plastic bits holding it in place and pry the panel up around the sides surrounding the fingerprint sensor and camera lens; set the back panel off to the side.
  4. LG V10 Headphone Jack Replacement: adım 4, 2 resimden 1. LG V10 Headphone Jack Replacement: adım 4, 2 resimden 2.
    • Carefully disconnect these two connectors by using the flat end of the plastic spudger to wedge the connectors away from the motherboard.
    • Use the plastic tweezers to pry the motherboard out from the plastic bits holding it in place.
  5. LG V10 Headphone Jack Replacement, Headphone Jack: adım 5, 2 resimden 1. LG V10 Headphone Jack Replacement, Headphone Jack: adım 5, 2 resimden 2.
    Satın Al
    • The headphone jack is located at the bottom right corner of the phone.
    • Carefully insert tweezers into the headphone jack and lift up.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Corey McDonough
237 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G6, Harley Spring 2019 IUPUI, Team S3-G6, Harley Spring 2019 üyesi
IUPUI-HARLEY-S19S3G6
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 407
