Ana içeriğe geç
LG V20 Headphone Jack Replacement
Neye ihtiyacın var
  1. LG V20 Headphone Jack Replacement, Back Cover: adım 1, 3 resimden 1. LG V20 Headphone Jack Replacement, Back Cover: adım 1, 3 resimden 2. LG V20 Headphone Jack Replacement, Back Cover: adım 1, 3 resimden 3.
    • Press the button on the lower right side of the LG V20 to open the clamp that holds the back cover on the back side of the phone.
    • Remove the back cover.
  2. LG V20 Headphone Jack Replacement, Battery: adım 2, 3 resimden 1. LG V20 Headphone Jack Replacement, Battery: adım 2, 3 resimden 2. LG V20 Headphone Jack Replacement, Battery: adım 2, 3 resimden 3.
    • Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
    • Be careful not to deform or puncture the battery.
    • Pry up and remove the battery.
  3. LG V20 Headphone Jack Replacement, Midframe Assembly: adım 3, 1 resimden 1.
    • Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
  4. LG V20 Headphone Jack Replacement: adım 4, 2 resimden 1. LG V20 Headphone Jack Replacement: adım 4, 2 resimden 2.
    • The top and bottom frame section hold very tight to the mid frame. It is possible to pull them off with your hands. If you're not able to do so, use the following removal procedure:
    • Use the flat end of a spudger and apply pressure to one of the corners of the frame section until you create a small gap.
  5. LG V20 Headphone Jack Replacement: adım 5, 2 resimden 1. LG V20 Headphone Jack Replacement: adım 5, 2 resimden 2.
    • Flip the phone and insert an opening pick in the gap you created.
    • Slide the opening pick along the gap until the frame section pops out of its plastic clamps.
  6. LG V20 Headphone Jack Replacement: adım 6, 1 resimden 1.
    • Remove the frame section.
    • Repeat this procedure with the frame section on the other end of the phone.
    • Within the top frame section there's a small silver grating that covers the speaker. This may fall out, so be careful not to lose it.
  7. LG V20 Headphone Jack Replacement: adım 7, 2 resimden 1. LG V20 Headphone Jack Replacement: adım 7, 2 resimden 2.
    • The loudspeaker is attached to the cover of the motherboard. Use an opening pick to pry it up.
  8. LG V20 Headphone Jack Replacement: adım 8, 2 resimden 1. LG V20 Headphone Jack Replacement: adım 8, 2 resimden 2.
    • The cover of the motherboard is held in its place by several plastic clamps.
    • Use an opening pick to pry up the motherboard cover at the right corner at the bottom of your phone until it pops out of the plastic clamp.
  9. LG V20 Headphone Jack Replacement: adım 9, 2 resimden 1. LG V20 Headphone Jack Replacement: adım 9, 2 resimden 2.
    • Slide the opening pick along the mid frame and flip it sideways to open the plastic clamps holding the motherboard cover in its place.
  10. LG V20 Headphone Jack Replacement: adım 10, 1 resimden 1.
    • Remove the motherboard cover.
  11. LG V20 Headphone Jack Replacement, Front-Facing Camera: adım 11, 2 resimden 1. LG V20 Headphone Jack Replacement, Front-Facing Camera: adım 11, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use the flat end of a spudger to disconnect the front camera flex cable.
    • If you want to go on and remove the motherboard assembly, there is no need to remove the front facing camera after disconnecting it. However if you feel uncertain, carefully remove it with a pair of tweezers.
    • Use a pair of tweezers to carefully remove the front facing camera. Be careful to only grip the body of the camera, as the top is the sensor pcb and is only held on with glue (removal will ruin the sensor).
  12. LG V20 Headphone Jack Replacement, Motherboard Assembly: adım 12, 1 resimden 1.
    • Use the flat end of a spudger to disconnect the flex cable of the left rear camera.
    • The second rear camera will come out with the motherboard since it is connected on the other side.
    • You can leave the front facing camera in its place as long as you're careful while removing the motherboard assembly. However if you feel uncertain, carefully remove it with a pair of tweezers.
  13. LG V20 Headphone Jack Replacement: adım 13, 1 resimden 1.
    • Disconnect the display flex cable with the flat end of a spudger.
  14. LG V20 Headphone Jack Replacement: adım 14, 2 resimden 1. LG V20 Headphone Jack Replacement: adım 14, 2 resimden 2.
    • Use the pointed end of a spudger to lift up the motherboard assembly until you can get a good grip.
    • Carefully lift up the motherboard assembly and remove it.
  15. LG V20 Headphone Jack Replacement, Headphone Jack: adım 15, 1 resimden 1.
    • Use an iOpener to loosen the adhesive beneath the headphone jack and its flex cable.
  16. LG V20 Headphone Jack Replacement: adım 16, 2 resimden 1. LG V20 Headphone Jack Replacement: adım 16, 2 resimden 2.
    • Use a pair of tweezers and gently remove the headphone jack by slowly pulling it up and out of its recess.
    • If the flex cable is glued in too tight, you might need to reapply the iOpener to soften the adhesive even more.
Sonuç
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where it’s necessary.
Bir başkası bu kılavuzu tamamladı.
Dominik Schnabelrauch
230.085 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.533 adet Kılavuz yazıldı
Bir Yorum
Jesus christ the bottom on mine is right, leaving it as I have nothing to fix just wanted to clean the ports
Kris Patel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 3,081
