Ana içeriğe geç
LG V20 MB Assembly Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. LG V20 MB Assembly Replacement, Battery: adım 1, 3 resimden 1. LG V20 MB Assembly Replacement, Battery: adım 1, 3 resimden 2. LG V20 MB Assembly Replacement, Battery: adım 1, 3 resimden 3.
    • Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
    • Be careful not to deform or puncture the battery.
    • Pry up and remove the battery.
  2. LG V20 MB Assembly Replacement, Midframe Assembly: adım 2, 1 resimden 1.
    • Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
  3. LG V20 MB Assembly Replacement: adım 3, 2 resimden 1. LG V20 MB Assembly Replacement: adım 3, 2 resimden 2.
    • The top and bottom frame section hold very tight to the mid frame. It is possible to pull them off with your hands. If you're not able to do so, use the following removal procedure:
    • Use the flat end of a spudger and apply pressure to one of the corners of the frame section until you create a small gap.
  4. LG V20 MB Assembly Replacement: adım 4, 2 resimden 1. LG V20 MB Assembly Replacement: adım 4, 2 resimden 2.
    • Flip the phone and insert an opening pick in the gap you created.
    • Slide the opening pick along the gap until the frame section pops out of its plastic clamps.
  5. LG V20 MB Assembly Replacement: adım 5, 1 resimden 1.
    • Remove the frame section.
    • Repeat this procedure with the frame section on the other end of the phone.
    • Within the top frame section there's a small silver grating that covers the speaker. This may fall out, so be careful not to lose it.
  6. LG V20 MB Assembly Replacement: adım 6, 2 resimden 1. LG V20 MB Assembly Replacement: adım 6, 2 resimden 2.
    • The loudspeaker is attached to the cover of the motherboard. Use an opening pick to pry it up.
  7. LG V20 MB Assembly Replacement: adım 7, 2 resimden 1. LG V20 MB Assembly Replacement: adım 7, 2 resimden 2.
    • The cover of the motherboard is held in its place by several plastic clamps.
    • Use an opening pick to pry up the motherboard cover at the right corner at the bottom of your phone until it pops out of the plastic clamp.
  8. LG V20 MB Assembly Replacement: adım 8, 2 resimden 1. LG V20 MB Assembly Replacement: adım 8, 2 resimden 2.
    • Slide the opening pick along the mid frame and flip it sideways to open the plastic clamps holding the motherboard cover in its place.
  9. LG V20 MB Assembly Replacement: adım 9, 1 resimden 1.
    • Remove the motherboard cover.
  10. LG V20 MB Assembly Replacement, Front-Facing Camera: adım 10, 2 resimden 1. LG V20 MB Assembly Replacement, Front-Facing Camera: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use the flat end of a spudger to disconnect the front camera flex cable.
    • If you want to go on and remove the motherboard assembly, there is no need to remove the front facing camera after disconnecting it. However if you feel uncertain, carefully remove it with a pair of tweezers.
    • Use a pair of tweezers to carefully remove the front facing camera. Be careful to only grip the body of the camera, as the top is the sensor pcb and is only held on with glue (removal will ruin the sensor).
  11. LG V20 MB Assembly Replacement, Motherboard Assembly: adım 11, 1 resimden 1.
    • Use the flat end of a spudger to disconnect the flex cable of the left rear camera.
    • The second rear camera will come out with the motherboard since it is connected on the other side.
    • You can leave the front facing camera in its place as long as you're careful while removing the motherboard assembly. However if you feel uncertain, carefully remove it with a pair of tweezers.
  12. LG V20 MB Assembly Replacement: adım 12, 1 resimden 1.
    • Disconnect the display flex cable with the flat end of a spudger.
  13. LG V20 MB Assembly Replacement: adım 13, 2 resimden 1. LG V20 MB Assembly Replacement: adım 13, 2 resimden 2.
    • Use the pointed end of a spudger to lift up the motherboard assembly until you can get a good grip.
    • Carefully lift up the motherboard assembly and remove it.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Max Wu
281 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G5, Livingston Spring 2017 Cal Poly, Team S22-G5, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S22G5
4 Üyeler
36 adet Kılavuz yazıldı
3Kılavuz Yorumları
Are the parts from the LG v20 h910 compatible with the LG V10 h900
Ryan Wolfe - Yanıt
I need to replace the motherboard on my LG V10 model h900 and all I have is an LG v20 model H 9100 will all the parts be compatible
Ryan Wolfe - Yanıt
Hello, where can I find the internal memory module for the LG V20?
enlil_ragas - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 23
Her zaman: 3,616
