Giriş
Use this guide to replace the midframe assembly of your LG V20.
Parçalar
Hiçbir parça belirtilmedi.
Press the button on the lower right side of the LG V20 to open the clamp that holds the back cover on the back side of the phone.
Remove the back cover.
Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
Be careful not to deform or puncture the battery.
Pry up and remove the battery.
Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
Bir başkası bu kılavuzu tamamladı.
