Giriş
Use this guide to replace the secondary rear-facing camera of your LG V20.
Neye ihtiyacın var
Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
Be careful not to deform or puncture the battery.
Pry up and remove the battery.
Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
Use an iOpener to loosen the adhesive beneath the secondary rear facing camera.
Bir başkası bu kılavuzu tamamladı.
