Giriş
Exposure to dirt or the shock of dropping a phone can damage volume buttons and cause them to become unresponsive. This guide will lead you through all the steps required to get your LG V20's volume button out of the phone and ready for replacement.
Neye ihtiyacın var
Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
Be careful not to deform or puncture the battery.
Pry up and remove the battery.
Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
Use the flat end of a spudger to slide the volume button out of its bracket and remove it.
7 farklı kişi bu kılavuzu tamamladı.
