Giriş
Phone screens are prone to crack when dropped from an elevated surface. Use this guide to remove the display assembly of your device.
Neye ihtiyacın var
Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
Allow to sit for 1-2 minutes to heat up the adhesive.
Gently push down on the small black tab with a Spudger to release the protective board.
Slide an Opening Tool between the phone and the protective board and slide along the edges of the phone to unclip it.
Carefully wiggle the board back and forth while gently pulling to unclip the last attachment point.
Use a Spudger to get between the battery and the phone and pry each edge of the battery away from the board.
Insert Opening Picks if needed to keep the battery elevated.
Use a Spudger to pry away the front-facing camera from the board.
Pull the ribbon cable attached to the screen away from the board and make sure it is bent upwards and out of the way.
2 farklı kişi bu kılavuzu tamamladı.
