Ana içeriğe geç
LG V30 Plus Front-Facing Camera Replacement
Neye ihtiyacın var
  1. LG V30 Plus Front-Facing Camera Replacement, Rear Glass: adım 1, 1 resimden 1.
    • Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
    • Allow to sit for 1-2 minutes to heat up the adhesive.
    • A heat gun may need to be used if you have trouble separating the backing in the next step.
  2. LG V30 Plus Front-Facing Camera Replacement: adım 2, 2 resimden 1. LG V30 Plus Front-Facing Camera Replacement: adım 2, 2 resimden 2.
    • Insert an Opening Tool into the seam between the rear glass and side of the phone.
    • Pry the glass off just enough to insert an Opening Pick.
    • Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
  3. LG V30 Plus Front-Facing Camera Replacement: adım 3, 1 resimden 1.
    • Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
  4. LG V30 Plus Front-Facing Camera Replacement, Motherboard: adım 4, 2 resimden 1. LG V30 Plus Front-Facing Camera Replacement, Motherboard: adım 4, 2 resimden 2.
    • Remove the ten 4mm screws using the Phillips #00 Screwdriver.
  5. LG V30 Plus Front-Facing Camera Replacement: adım 5, 3 resimden 1. LG V30 Plus Front-Facing Camera Replacement: adım 5, 3 resimden 2. LG V30 Plus Front-Facing Camera Replacement: adım 5, 3 resimden 3.
    • Gently push down on the small black tab with a Spudger to release the protective board.
    • Slide an Opening Tool between the phone and the protective board and slide along the edges of the phone to unclip it.
    • Carefully wiggle the board back and forth while gently pulling to unclip the last attachment point.
  6. LG V30 Plus Front-Facing Camera Replacement: adım 6, 2 resimden 1. LG V30 Plus Front-Facing Camera Replacement: adım 6, 2 resimden 2.
    • Slide an Opening Tool between the lower protective board and the phone to unclip.
    • Slide the tool along the remaining edges of the protective board until it pops off.
  7. LG V30 Plus Front-Facing Camera Replacement: adım 7, 2 resimden 1. LG V30 Plus Front-Facing Camera Replacement: adım 7, 2 resimden 2.
    • Gently pry each visible ribbon cable away from the motherboard to disconnect them.
  8. LG V30 Plus Front-Facing Camera Replacement: adım 8, 1 resimden 1.
    • Gently remove the motherboard from the phone.
  9. LG V30 Plus Front-Facing Camera Replacement, Battery: adım 9, 3 resimden 1. LG V30 Plus Front-Facing Camera Replacement, Battery: adım 9, 3 resimden 2. LG V30 Plus Front-Facing Camera Replacement, Battery: adım 9, 3 resimden 3.
    • Use a Spudger to get between the battery and the phone and pry each edge of the battery away from the board.
    • There may be a strong adhesive under the battery, so work your way around the battery carefully and slowly.
    • Insert Opening Picks if needed to keep the battery elevated.
  10. LG V30 Plus Front-Facing Camera Replacement, Front-Facing Camera: adım 10, 2 resimden 1. LG V30 Plus Front-Facing Camera Replacement, Front-Facing Camera: adım 10, 2 resimden 2.
    • Use a Spudger to pry away the front-facing camera from the board.
Sonuç
Samuel Jahnke
279 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G3, Maness Spring 2019 Cal Poly, Team S1-G3, Maness Spring 2019 üyesi
CPSU-MANESS-S19S1G3
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 264
