Ana içeriğe geç
LG V30 Plus Rear Glass Replacement
Neye ihtiyacın var
  1. LG V30 Plus Rear Glass Replacement, Rear Glass: adım 1, 1 resimden 1.
    • Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
    • Allow to sit for 1-2 minutes to heat up the adhesive.
    • A heat gun may need to be used if you have trouble separating the backing in the next step.
  2. LG V30 Plus Rear Glass Replacement: adım 2, 2 resimden 1. LG V30 Plus Rear Glass Replacement: adım 2, 2 resimden 2.
    • Insert an Opening Tool into the seam between the rear glass and side of the phone.
    • Pry the glass off just enough to insert an Opening Pick.
    • Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
  3. LG V30 Plus Rear Glass Replacement: adım 3, 1 resimden 1.
    • Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
Sonuç
Geoffrey Smith
395 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G3, Maness Spring 2019 Cal Poly, Team S1-G3, Maness Spring 2019 üyesi
CPSU-MANESS-S19S1G3
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 1,035
