Ana içeriğe geç
LG VX4400 Screen Replacement
Neye ihtiyacın var
  1. LG VX4400 Screen Replacement, Screen: adım 1, 2 resimden 1. LG VX4400 Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Remove the four rubber stoppers around the main screen using the pointed end of the spudger.
  2. LG VX4400 Screen Replacement: adım 2, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the four screws that were under the rubber stoppers.
  3. LG VX4400 Screen Replacement: adım 3, 3 resimden 1. LG VX4400 Screen Replacement: adım 3, 3 resimden 2. LG VX4400 Screen Replacement: adım 3, 3 resimden 3.
    • Use a plastic opening tool to pry the top end of the phone open.
    • Use a second plastic opening tool to slide down the gap and pry open the case while prying the top panel with the first plastic opening tool.
    • Use the same method on the opposite side of the phone.
  4. LG VX4400 Screen Replacement: adım 4, 2 resimden 1. LG VX4400 Screen Replacement: adım 4, 2 resimden 2.
    • Remove plastic screen panel to reveal the internal components.
  5. LG VX4400 Screen Replacement: adım 5, 3 resimden 1. LG VX4400 Screen Replacement: adım 5, 3 resimden 2. LG VX4400 Screen Replacement: adım 5, 3 resimden 3.
    • Remove the screen board by lifting it away from the phone.
    • Remove the speaker by prying with the spudger.
  6. LG VX4400 Screen Replacement: adım 6, 3 resimden 1. LG VX4400 Screen Replacement: adım 6, 3 resimden 2. LG VX4400 Screen Replacement: adım 6, 3 resimden 3.
    • Press out the plastic screen gently.
Sonuç
Nico Chiarito
22 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-47, Regan Winter 2010 Cal Poly, Team 8-47, Regan Winter 2010 üyesi
CPSU-REGAN-W10S8G47
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 2,476
