Ana içeriğe geç
LG VX4500 Keypad Replacement
Neye ihtiyacın var
    1. LG VX4500 Keypad Replacement, Battery: adım 1, 1 resimden 1.
      • Turn the closed phone so that the back panel is facing you.
      • Press down and forward firmly on the gray tab in the middle of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. LG VX4500 Keypad Replacement: adım 2, 2 resimden 1. LG VX4500 Keypad Replacement: adım 2, 2 resimden 2.
      • Now just lift up on the battery and remove it from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. LG VX4500 Keypad Replacement, Rear Cover: adım 3, 1 resimden 1.
      • Remove the rubber grommet using a spudger.
      FixBot'a Sor
      Yorum Ekle
    2. LG VX4500 Keypad Replacement: adım 4, 1 resimden 1.
      • Be sure not to lose the screws. They are small!
      • Remove the five screws using a Phillips #00 Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. LG VX4500 Keypad Replacement: adım 5, 3 resimden 1. LG VX4500 Keypad Replacement: adım 5, 3 resimden 2. LG VX4500 Keypad Replacement: adım 5, 3 resimden 3.
      Bu adımda kullanılan alet:
      • When removing back cover, be careful not to break the speaker wires.
      • Using an Opening Tool, carefully pry off the back cover.
      • Using tweezers, gently pull the speaker wires out.
      FixBot'a Sor
      Yorum Ekle
    4. LG VX4500 Keypad Replacement: adım 6, 1 resimden 1.
      • Separate the two halves.
      FixBot'a Sor
      Yorum Ekle
    1. LG VX4500 Keypad Replacement, Keypad: adım 7, 3 resimden 1. LG VX4500 Keypad Replacement, Keypad: adım 7, 3 resimden 2. LG VX4500 Keypad Replacement, Keypad: adım 7, 3 resimden 3.
      • Carefully pry and lift up on the logic board using an iPod Opening Tool.
      FixBot'a Sor
      Yorum Ekle
    2. LG VX4500 Keypad Replacement: adım 8, 1 resimden 1.
      • Carefully flip the logic board up and out of the way.
      FixBot'a Sor
      Yorum Ekle
    3. LG VX4500 Keypad Replacement: adım 9, 3 resimden 1. LG VX4500 Keypad Replacement: adım 9, 3 resimden 2. LG VX4500 Keypad Replacement: adım 9, 3 resimden 3.
      • Use an iPod Opening Tool to lift up on the keypad and pull it out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
David Foster
1 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-88, Amido Spring 2010 Cal Poly, Team 25-88, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S25G88
4 Üyeler
90 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 26
Her zaman: 1,297
