Ana içeriğe geç
LG VX4500 Speaker Replacement
Neye ihtiyacın var
  1. LG VX4500 Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the closed phone so that the back panel is facing you.
    • Press down and forward firmly on the gray tab in the middle of the phone.
  2. LG VX4500 Speaker Replacement: adım 2, 2 resimden 1. LG VX4500 Speaker Replacement: adım 2, 2 resimden 2.
    • Now just lift up on the battery and remove it from the phone.
  3. LG VX4500 Speaker Replacement, Rear Cover: adım 3, 1 resimden 1.
    • Remove the rubber grommet using a spudger.
  4. LG VX4500 Speaker Replacement: adım 4, 1 resimden 1.
    • Be sure not to lose the screws. They are small!
    • Remove the five screws using a Phillips #00 Screwdriver.
  5. LG VX4500 Speaker Replacement: adım 5, 3 resimden 1. LG VX4500 Speaker Replacement: adım 5, 3 resimden 2. LG VX4500 Speaker Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • When removing back cover, be careful not to break the speaker wires.
    • Using an Opening Tool, carefully pry off the back cover.
    • Using tweezers, gently pull the speaker wires out.
  6. LG VX4500 Speaker Replacement: adım 6, 1 resimden 1.
    • Separate the two halves.
  7. LG VX4500 Speaker Replacement, Speaker: adım 7, 2 resimden 1. LG VX4500 Speaker Replacement, Speaker: adım 7, 2 resimden 2.
    • Take top half of phone and pry up speaker using the Spudger.
  8. LG VX4500 Speaker Replacement: adım 8, 1 resimden 1.
    • Lift out speaker.
Sonuç
David Foster
1 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-88, Amido Spring 2010 Cal Poly, Team 25-88, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S25G88
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 1,961
