Ana içeriğe geç
LG VX4500 display interconnect cable
Neye ihtiyacın var
  1. LG VX4500 display interconnect cable, Battery: adım 1, 1 resimden 1.
    • Turn the closed phone so that the back panel is facing you.
    • Press down and forward firmly on the gray tab in the middle of the phone.
  2. LG VX4500 display interconnect cable: adım 2, 2 resimden 1. LG VX4500 display interconnect cable: adım 2, 2 resimden 2.
    • Now just lift up on the battery and remove it from the phone.
  3. LG VX4500 display interconnect cable, Rear Cover: adım 3, 1 resimden 1.
    • Remove the rubber grommet using a Spudger.
  4. LG VX4500 display interconnect cable: adım 4, 1 resimden 1.
    • Be sure not to lose the screws. They are small!
    • Remove the five screws using a Phillips #00 Screwdriver.
  5. LG VX4500 display interconnect cable: adım 5, 3 resimden 1. LG VX4500 display interconnect cable: adım 5, 3 resimden 2. LG VX4500 display interconnect cable: adım 5, 3 resimden 3.
    • When removing back cover, be careful not to break the speaker wires.
    • Using an Opening Tool, carefully pry off the back cover.
    • Using tweezers, gently pull the speaker wires out.
  6. LG VX4500 display interconnect cable: adım 6, 1 resimden 1.
    • Separate the two halves.
  7. LG VX4500 display interconnect cable, Keypad: adım 7, 3 resimden 1. LG VX4500 display interconnect cable, Keypad: adım 7, 3 resimden 2. LG VX4500 display interconnect cable, Keypad: adım 7, 3 resimden 3.
    • Carefully pry and lift up on the logic board using an iPod Opening Tool.
  8. LG VX4500 display interconnect cable: adım 8, 1 resimden 1.
    • Carefully flip the logic board up and out of the way.
  9. LG VX4500 display interconnect cable: adım 9, 3 resimden 1. LG VX4500 display interconnect cable: adım 9, 3 resimden 2. LG VX4500 display interconnect cable: adım 9, 3 resimden 3.
    • Use an iPod Opening Tool to lift up on the keypad and pull it out.
  10. LG VX4500 display interconnect cable, Motherboard: adım 10, 1 resimden 1.
    • DO NOT TOUCH SOLDERING IRON. IT IS EXTREMELY HOT.
    • Use a soldering iron to desolder the solder joint on the front of the motherboard.
    • If you need more information on soldering, refer to this guide.
  11. LG VX4500 display interconnect cable: adım 11, 1 resimden 1.
    • Desolder the joint on the back using a soldering iron.
  12. LG VX4500 display interconnect cable: adım 12, 3 resimden 1. LG VX4500 display interconnect cable: adım 12, 3 resimden 2. LG VX4500 display interconnect cable: adım 12, 3 resimden 3.
    • Carefully detach the ribbon cable and remove the motherboard.
  13. LG VX4500 display interconnect cable, Outer Display Cover: adım 13, 1 resimden 1.
    • Remove 4 rubber grommets using the Spudger.
  14. LG VX4500 display interconnect cable: adım 14, 1 resimden 1.
    • Remove 4 screws using the Phillips #00 Screwdriver.
  15. LG VX4500 display interconnect cable: adım 15, 3 resimden 1. LG VX4500 display interconnect cable: adım 15, 3 resimden 2. LG VX4500 display interconnect cable: adım 15, 3 resimden 3.
    • Carefully pry off outer cover using iPod Opening Tool.
  16. LG VX4500 display interconnect cable, Display: adım 16, 2 resimden 1. LG VX4500 display interconnect cable, Display: adım 16, 2 resimden 2.
    • Remove speaker using the Spudger.
  17. LG VX4500 display interconnect cable: adım 17, 2 resimden 1. LG VX4500 display interconnect cable: adım 17, 2 resimden 2.
    • Remove vibrator using the Spudger.
  18. LG VX4500 display interconnect cable: adım 18, 2 resimden 1. LG VX4500 display interconnect cable: adım 18, 2 resimden 2.
    • Lift up LCD display using iPod Opening Tool.
  19. LG VX4500 display interconnect cable: adım 19, 1 resimden 1.
    • DO NOT TOUCH THE SOLDERING IRON. IT IS EXTREMELY HOT!
    • De-solder solder joint using Soldering Iron.
  20. LG VX4500 display interconnect cable: adım 20, 2 resimden 1. LG VX4500 display interconnect cable: adım 20, 2 resimden 2.
    • Pry off ribbon cable using iPod Opening Tool.
  21. LG VX4500 display interconnect cable, Ribbon Cable: adım 21, 3 resimden 1. LG VX4500 display interconnect cable, Ribbon Cable: adım 21, 3 resimden 2. LG VX4500 display interconnect cable, Ribbon Cable: adım 21, 3 resimden 3.
    • Turn phone so that the back side is facing you.
    • Press blue button and remove top half using Spudger.
  22. LG VX4500 display interconnect cable: adım 22, 2 resimden 1. LG VX4500 display interconnect cable: adım 22, 2 resimden 2.
    • Remove cable from bottom section.
Sonuç
David Foster
1 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-88, Amido Spring 2010 Cal Poly, Team 25-88, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S25G88
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 3,179
