Ana içeriğe geç
LG VX4500 Display Screen Replacement
Neye ihtiyacın var
  1. LG VX4500 Display Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the closed phone so that the back panel is facing you.
    • Press down and forward firmly on the gray tab in the middle of the phone.
  2. LG VX4500 Display Screen Replacement: adım 2, 2 resimden 1. LG VX4500 Display Screen Replacement: adım 2, 2 resimden 2.
    • Now just lift up on the battery and remove it from the phone.
  3. LG VX4500 Display Screen Replacement, Outer Display Cover: adım 3, 1 resimden 1.
    • Remove 4 rubber grommets using the Spudger.
  4. LG VX4500 Display Screen Replacement: adım 4, 1 resimden 1.
    • Remove 4 screws using the Phillips #00 Screwdriver.
  5. LG VX4500 Display Screen Replacement: adım 5, 3 resimden 1. LG VX4500 Display Screen Replacement: adım 5, 3 resimden 2. LG VX4500 Display Screen Replacement: adım 5, 3 resimden 3.
    • Carefully pry off outer cover using iPod Opening Tool.
  6. LG VX4500 Display Screen Replacement, Display: adım 6, 2 resimden 1. LG VX4500 Display Screen Replacement, Display: adım 6, 2 resimden 2.
    • Remove speaker using the Spudger.
  7. LG VX4500 Display Screen Replacement: adım 7, 2 resimden 1. LG VX4500 Display Screen Replacement: adım 7, 2 resimden 2.
    • Remove vibrator using the Spudger.
  8. LG VX4500 Display Screen Replacement: adım 8, 2 resimden 1. LG VX4500 Display Screen Replacement: adım 8, 2 resimden 2.
    • Lift up LCD display using iPod Opening Tool.
  9. LG VX4500 Display Screen Replacement: adım 9, 1 resimden 1.
    • DO NOT TOUCH THE SOLDERING IRON. IT IS EXTREMELY HOT!
    • De-solder solder joint using Soldering Iron.
  10. LG VX4500 Display Screen Replacement: adım 10, 2 resimden 1. LG VX4500 Display Screen Replacement: adım 10, 2 resimden 2.
    • Pry off ribbon cable using iPod Opening Tool.
Sonuç
David Foster
1 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-88, Amido Spring 2010 Cal Poly, Team 25-88, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S25G88
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 2,296
