Ana içeriğe geç
LG VX5200 Face Plate Replacement
Neye ihtiyacın var
  1. LG VX5200 Face Plate Replacement, Battery: adım 1, 2 resimden 1. LG VX5200 Face Plate Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the phone on its back.
  2. LG VX5200 Face Plate Replacement: adım 2, 2 resimden 1. LG VX5200 Face Plate Replacement: adım 2, 2 resimden 2.
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 Face Plate Replacement: adım 3, 2 resimden 1. LG VX5200 Face Plate Replacement: adım 3, 2 resimden 2.
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 Face Plate Replacement, Face Plate: adım 4, 3 resimden 1. LG VX5200 Face Plate Replacement, Face Plate: adım 4, 3 resimden 2. LG VX5200 Face Plate Replacement, Face Plate: adım 4, 3 resimden 3.
    • Flip the phone open.
    • Remove the four rubber plugs, located at the corners of the LCD screen, with a push-pin.
    • Use a Phillips #00 screwdriver to remove the four screws located underneath the rubber plugs.
  5. LG VX5200 Face Plate Replacement: adım 5, 3 resimden 1. LG VX5200 Face Plate Replacement: adım 5, 3 resimden 2. LG VX5200 Face Plate Replacement: adım 5, 3 resimden 3.
    • Insert the opening tool in the seam of the top portion of the flip phone.
    • Gently pry the seam open.
    • Move the opening tool around the perimeter of the seam and gently take the front LCD face plate out.
  6. LG VX5200 Face Plate Replacement: adım 6, 3 resimden 1. LG VX5200 Face Plate Replacement: adım 6, 3 resimden 2. LG VX5200 Face Plate Replacement: adım 6, 3 resimden 3.
    • Close the flip phone.
    • Hold the base of the phone and gently remove the faceplate.
    • Place the phone and the faceplate on a clean, flat surface.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Douglas Blaalid
282 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-13, Forte Winter 2010 Cal Poly, Team 4-13, Forte Winter 2010 üyesi
CPSU-FORTE-W10S4G13
5 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 2,053
