Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Orient the phone as shown.
Remove the battery cover by pushing upward with your thumb.
Place your fingernail at the top of the battery and pry the battery out towards you.
Flip the phone open.
Remove the four rubber plugs, located at the corners of the LCD screen, with a push-pin.
Use a Phillips #00 screwdriver to remove the four screws located underneath the rubber plugs.
Insert the opening tool in the seam of the top portion of the flip phone.
Gently pry the seam open.
Move the opening tool around the perimeter of the seam and gently take the front LCD face plate out.
Close the flip phone.
Hold the base of the phone and gently remove the faceplate.
Place the phone and the faceplate on a clean, flat surface.
Bir başkası bu kılavuzu tamamladı.
