Ana içeriğe geç
LG VX5200 Keypad Replacement
Neye ihtiyacın var
  1. LG VX5200 Keypad Replacement, Battery: adım 1, 2 resimden 1. LG VX5200 Keypad Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the phone on its back.
  2. LG VX5200 Keypad Replacement: adım 2, 2 resimden 1. LG VX5200 Keypad Replacement: adım 2, 2 resimden 2.
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 Keypad Replacement: adım 3, 2 resimden 1. LG VX5200 Keypad Replacement: adım 3, 2 resimden 2.
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 Keypad Replacement, LG VX5200 Rear Body Panel Disassembly: adım 4, 1 resimden 1.
    • Orient the phone as shown with the battery already removed.
  5. LG VX5200 Keypad Replacement: adım 5, 3 resimden 1. LG VX5200 Keypad Replacement: adım 5, 3 resimden 2. LG VX5200 Keypad Replacement: adım 5, 3 resimden 3.
    • Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
    • Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
  6. LG VX5200 Keypad Replacement: adım 6, 3 resimden 1. LG VX5200 Keypad Replacement: adım 6, 3 resimden 2. LG VX5200 Keypad Replacement: adım 6, 3 resimden 3.
    • Place an iPod opener tool in the seam above the antenna.
    • Run the tool around the perimeter of the entire phone.
  7. LG VX5200 Keypad Replacement: adım 7, 1 resimden 1.
    • Check to see that your device looks like the attached photo.
  8. LG VX5200 Keypad Replacement, main board: adım 8, 3 resimden 1. LG VX5200 Keypad Replacement, main board: adım 8, 3 resimden 2. LG VX5200 Keypad Replacement, main board: adım 8, 3 resimden 3.
    • Locate the tabs that hold the logic board in place.
    • Pull the outer frame of the phone outwards to release the board from the tabs.
  9. LG VX5200 Keypad Replacement: adım 9, 3 resimden 1. LG VX5200 Keypad Replacement: adım 9, 3 resimden 2. LG VX5200 Keypad Replacement: adım 9, 3 resimden 3.
    • Locate the copper connection (orange-colored) on the back of the board.
    • Pry the connector free from the board with your fingernail.
  10. LG VX5200 Keypad Replacement: adım 10, 1 resimden 1.
    • Check to see that your device looks like the image shown.
    • Note: The image is shown with the LCD screen removed. This is not necessary for logic board removal.
  11. LG VX5200 Keypad Replacement, Keypad: adım 11, 3 resimden 1. LG VX5200 Keypad Replacement, Keypad: adım 11, 3 resimden 2. LG VX5200 Keypad Replacement, Keypad: adım 11, 3 resimden 3.
    • Use your finger to lift up the keypad.
  12. LG VX5200 Keypad Replacement: adım 12, 1 resimden 1.
    • Do not let the buttons fall out of the side casing of the phone!
    • Note: The image is shown with the LCD screen removed. This is not necessary for keypad repair.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Douglas Blaalid
282 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-13, Forte Winter 2010 Cal Poly, Team 4-13, Forte Winter 2010 üyesi
CPSU-FORTE-W10S4G13
5 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 1,995
