Ana içeriğe geç
LG VX5200 LCD Screen Replacement
Neye ihtiyacın var
  1. LG VX5200 LCD Screen Replacement, Battery: adım 1, 2 resimden 1. LG VX5200 LCD Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the phone on its back.
  2. LG VX5200 LCD Screen Replacement: adım 2, 2 resimden 1. LG VX5200 LCD Screen Replacement: adım 2, 2 resimden 2.
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 LCD Screen Replacement: adım 3, 2 resimden 1. LG VX5200 LCD Screen Replacement: adım 3, 2 resimden 2.
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 LCD Screen Replacement, Face Plate: adım 4, 3 resimden 1. LG VX5200 LCD Screen Replacement, Face Plate: adım 4, 3 resimden 2. LG VX5200 LCD Screen Replacement, Face Plate: adım 4, 3 resimden 3.
    • Flip the phone open.
    • Remove the four rubber plugs, located at the corners of the LCD screen, with a push-pin.
    • Use a Phillips #00 screwdriver to remove the four screws located underneath the rubber plugs.
  5. LG VX5200 LCD Screen Replacement: adım 5, 3 resimden 1. LG VX5200 LCD Screen Replacement: adım 5, 3 resimden 2. LG VX5200 LCD Screen Replacement: adım 5, 3 resimden 3.
    • Insert the opening tool in the seam of the top portion of the flip phone.
    • Gently pry the seam open.
    • Move the opening tool around the perimeter of the seam and gently take the front LCD face plate out.
  6. LG VX5200 LCD Screen Replacement: adım 6, 3 resimden 1. LG VX5200 LCD Screen Replacement: adım 6, 3 resimden 2. LG VX5200 LCD Screen Replacement: adım 6, 3 resimden 3.
    • Close the flip phone.
    • Hold the base of the phone and gently remove the faceplate.
    • Place the phone and the faceplate on a clean, flat surface.
  7. LG VX5200 LCD Screen Replacement, LCD Screen: adım 7, 2 resimden 1. LG VX5200 LCD Screen Replacement, LCD Screen: adım 7, 2 resimden 2.
    • Try not to move the thin component wires as they will bend and break very easily.
  8. LG VX5200 LCD Screen Replacement: adım 8, 3 resimden 1. LG VX5200 LCD Screen Replacement: adım 8, 3 resimden 2. LG VX5200 LCD Screen Replacement: adım 8, 3 resimden 3.
    • Remove the white stopper from the camera light located above the gold connector.
    • Lift the gold connector up with your finger to detach it.
  9. LG VX5200 LCD Screen Replacement: adım 9, 1 resimden 1.
    • Gently lift out the speaker with your fingertip.
  10. LG VX5200 LCD Screen Replacement: adım 10, 3 resimden 1. LG VX5200 LCD Screen Replacement: adım 10, 3 resimden 2. LG VX5200 LCD Screen Replacement: adım 10, 3 resimden 3.
    • Gently lift out the square LCD assembly being careful with the attached vibrator wires.
    • Gently remove the vibrator with tweezers.
    • The LCD screen, speaker and vibrator will separate from the phone as a single unit.
  11. LG VX5200 LCD Screen Replacement: adım 11, 2 resimden 1. LG VX5200 LCD Screen Replacement: adım 11, 2 resimden 2.
    • Place phone body and LCD screen on a clean, lint-free surface.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Douglas Blaalid
282 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-13, Forte Winter 2010 Cal Poly, Team 4-13, Forte Winter 2010 üyesi
CPSU-FORTE-W10S4G13
5 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 3,841
