Ana içeriğe geç
LG VX5200 Screen Replacement
Neye ihtiyacın var
  1. LG VX5200 Screen Replacement, Screen: adım 1, 3 resimden 1. LG VX5200 Screen Replacement, Screen: adım 1, 3 resimden 2. LG VX5200 Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Pry the grey pieces of plastic off the corners of the screen with a spudger.
  2. LG VX5200 Screen Replacement: adım 2, 2 resimden 1. LG VX5200 Screen Replacement: adım 2, 2 resimden 2.
    • Unscrew each of the four screws with a Phillips #00 Screwdriver.
    • These screws are the same size as the ones from the back casing, but are not the same size as the screw from the antenna.
  3. LG VX5200 Screen Replacement: adım 3, 2 resimden 1. LG VX5200 Screen Replacement: adım 3, 2 resimden 2.
    • Close the phone after removing the screws.
    • Slide a spudger into the cracks in the top half of the phone's casing.
    • Wedge and lever the spudger to remove the casing.
    • Apply constant pressure to avoid cracking the plastic casing. This step can take a few minutes.
  4. LG VX5200 Screen Replacement: adım 4, 3 resimden 1. LG VX5200 Screen Replacement: adım 4, 3 resimden 2. LG VX5200 Screen Replacement: adım 4, 3 resimden 3.
    • Remove the chipboard from the screen by sliding a plastic spudger under the screen and lifting.
    • Use a plastic spudger to avoid short-circuiting the phone's electronics.
    • Gently lift the speaker out of the plastic casing using a plastic spudger.
    • Remove the small battery adjacent to the speaker with a plastic spudger.
  5. LG VX5200 Screen Replacement: adım 5, 3 resimden 1. LG VX5200 Screen Replacement: adım 5, 3 resimden 2. LG VX5200 Screen Replacement: adım 5, 3 resimden 3.
    • Slide and lever a plastic spudger between the screen and it's housing.
    • Avoid tearing the wires connecting the screen, the small battery and the speaker.
    • Remove the chip connecting the screen to the camera using your fingers.
Sonuç
jmarcum
16 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 9-18, Regan Fall 2009 Cal Poly, Team 9-18, Regan Fall 2009 üyesi
CPSU-REGAN-F09S9G18
5 Üyeler
2 adet Kılavuz yazıldı
1Rehber Yorum
The “battery” beside the speaker isn’t the battery, it’s the phone vibrator. Still a good guide, however
Kaleb White - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 3,579
