Ana içeriğe geç
LG VX5400 Keypad Replacement
Neye ihtiyacın var
    1. LG VX5400 Keypad Replacement, Battery: adım 1, 1 resimden 1.
      • Turn off the cell phone and turn it over on its back side
      FixBot'a Sor
      Yorum Ekle
    2. LG VX5400 Keypad Replacement: adım 2, 1 resimden 1.
      • Hold the phone case in your palm and slide the back cover towards yourself using your thumb
      FixBot'a Sor
      Yorum Ekle
    3. LG VX5400 Keypad Replacement: adım 3, 3 resimden 1. LG VX5400 Keypad Replacement: adım 3, 3 resimden 2. LG VX5400 Keypad Replacement: adım 3, 3 resimden 3.
      • Slide a tool or finger into the notch at the top of the battery to carefully remove it.
      FixBot'a Sor
      Yorum Ekle
    1. LG VX5400 Keypad Replacement, Keypad: adım 4, 1 resimden 1.
      • Remove the rubber stopper from the back top of the phone with the pointed end of a spudger.
      FixBot'a Sor
      Yorum Ekle
    2. LG VX5400 Keypad Replacement: adım 5, 1 resimden 1.
      • Use the Phillip screw driver to remove the hidden screw, which is marked by the red square
      FixBot'a Sor
      Yorum Ekle
    3. LG VX5400 Keypad Replacement: adım 6, 1 resimden 1.
      • Gently split open the front and back of the bottom casing of the phone with fingers.
      FixBot'a Sor
      Yorum Ekle
    4. LG VX5400 Keypad Replacement: adım 7, 1 resimden 1.
      • Carefully pull the key pad from the phone through the opening.
      FixBot'a Sor
      Yorum Ekle
    5. LG VX5400 Keypad Replacement: adım 8, 1 resimden 1.
      • See here for parts that have been removed.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Ekip
Cal Poly, Team 26-26, Regan Spring 2010 Cal Poly, Team 26-26, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G26
4 Üyeler
50 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 39
Her zaman: 2,721
