Ana içeriğe geç
LG VX5400 Logic Board Replacement
Neye ihtiyacın var
    1. LG VX5400 Logic Board Replacement, Battery: adım 1, 1 resimden 1.
      • Turn off the cell phone and turn it over on its back side
      FixBot'a Sor
      Yorum Ekle
    2. LG VX5400 Logic Board Replacement: adım 2, 1 resimden 1.
      • Hold the phone case in your palm and slide the back cover towards yourself using your thumb
      FixBot'a Sor
      Yorum Ekle
    3. LG VX5400 Logic Board Replacement: adım 3, 3 resimden 1. LG VX5400 Logic Board Replacement: adım 3, 3 resimden 2. LG VX5400 Logic Board Replacement: adım 3, 3 resimden 3.
      • Slide a tool or finger into the notch at the top of the battery to carefully remove it.
      FixBot'a Sor
      Yorum Ekle
    1. LG VX5400 Logic Board Replacement, Outer Casing: adım 4, 1 resimden 1.
      • Take the Philips screwdriver and unscrew the four visible screws on the backside of the phone indicated by the four red circles.
      FixBot'a Sor
      Yorum Ekle
    2. LG VX5400 Logic Board Replacement: adım 5, 1 resimden 1.
      • Then, take the pointed end of a spudger and pry out the rubber stopper to reveal the last screw at the top indicated with the blue circle.
      FixBot'a Sor
      Yorum Ekle
    1. LG VX5400 Logic Board Replacement, Logic Board: adım 6, 2 resimden 1. LG VX5400 Logic Board Replacement, Logic Board: adım 6, 2 resimden 2.
      • While the phone is open and faced up, carefully insert a tool into the middle to seperate the bottom half of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. LG VX5400 Logic Board Replacement: adım 7, 2 resimden 1. LG VX5400 Logic Board Replacement: adım 7, 2 resimden 2.
      • Carefully slide out the keypad and remove the logic board. Then insert new the logic board.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sourabh
132 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 26-26, Regan Spring 2010 Cal Poly, Team 26-26, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G26
4 Üyeler
50 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 26
Her zaman: 2,851
