Ana içeriğe geç
LG VX5400 Logic Board Replacement
Neye ihtiyacın var
  1. LG VX5400 Logic Board Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the cell phone and turn it over on its back side
  2. LG VX5400 Logic Board Replacement: adım 2, 1 resimden 1.
    • Hold the phone case in your palm and slide the back cover towards yourself using your thumb
  3. LG VX5400 Logic Board Replacement: adım 3, 3 resimden 1. LG VX5400 Logic Board Replacement: adım 3, 3 resimden 2. LG VX5400 Logic Board Replacement: adım 3, 3 resimden 3.
    • Slide a tool or finger into the notch at the top of the battery to carefully remove it.
  4. LG VX5400 Logic Board Replacement, Outer Casing: adım 4, 1 resimden 1.
    • Take the Philips screwdriver and unscrew the four visible screws on the backside of the phone indicated by the four red circles.
  5. LG VX5400 Logic Board Replacement: adım 5, 1 resimden 1.
    • Then, take the pointed end of a spudger and pry out the rubber stopper to reveal the last screw at the top indicated with the blue circle.
  6. LG VX5400 Logic Board Replacement, Logic Board: adım 6, 2 resimden 1. LG VX5400 Logic Board Replacement, Logic Board: adım 6, 2 resimden 2.
    • While the phone is open and faced up, carefully insert a tool into the middle to seperate the bottom half of the phone.
  7. LG VX5400 Logic Board Replacement: adım 7, 2 resimden 1. LG VX5400 Logic Board Replacement: adım 7, 2 resimden 2.
    • Carefully slide out the keypad and remove the logic board. Then insert new the logic board.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sourabh
132 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 26-26, Regan Spring 2010 Cal Poly, Team 26-26, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G26
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 2,534
