Ana içeriğe geç
LG VX5500 Audio Port Replacement
Neye ihtiyacın var
    1. LG VX5500 Audio Port Replacement, Battery: adım 1, 3 resimden 1. LG VX5500 Audio Port Replacement, Battery: adım 1, 3 resimden 2. LG VX5500 Audio Port Replacement, Battery: adım 1, 3 resimden 3.
      • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
      • Our device did not come with a battery cover so it is not shown here.
      • Remove the battery using your finger to pry it out of the battery housing.
      FixBot'a Sor
      Yorum Ekle
    1. LG VX5500 Audio Port Replacement, Audio Port: adım 2, 2 resimden 1. LG VX5500 Audio Port Replacement, Audio Port: adım 2, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack.
      • Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
      FixBot'a Sor
      Yorum Ekle
    2. LG VX5500 Audio Port Replacement: adım 3, 3 resimden 1. LG VX5500 Audio Port Replacement: adım 3, 3 resimden 2. LG VX5500 Audio Port Replacement: adım 3, 3 resimden 3.
      • Carefully pry off the phone's backing using a plastic opening tool.
      • Slip the tool into the crack between the keypad (front panel) and the back panel.
      • Slide the tool along the sides of the phone to detach the tabs holding the backing on.
      FixBot'a Sor
      Yorum Ekle
    3. LG VX5500 Audio Port Replacement: adım 4, 2 resimden 1. LG VX5500 Audio Port Replacement: adım 4, 2 resimden 2.
      • Locate the audio port; this is what it should look like.
      • The audio port is mounted and connected at 6 points. Check the integrity of these connections.
      • If any of the connections are dislodged or the audio port is damaged, desolder the port and install a new one.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kurt Beske
70 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 7-33, Maness Spring 2012 Cal Poly, Team 7-33, Maness Spring 2012 üyesi
CPSU-MANESS-S12S7G33
4 Üyeler
50 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 30
Her zaman: 787
