Ana içeriğe geç
LG VX5500 Audio Port Replacement
Neye ihtiyacın var
  1. LG VX5500 Audio Port Replacement, Battery: adım 1, 3 resimden 1. LG VX5500 Audio Port Replacement, Battery: adım 1, 3 resimden 2. LG VX5500 Audio Port Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
    • Our device did not come with a battery cover so it is not shown here.
    • Remove the battery using your finger to pry it out of the battery housing.
  2. LG VX5500 Audio Port Replacement, Audio Port: adım 2, 2 resimden 1. LG VX5500 Audio Port Replacement, Audio Port: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack.
    • Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
  3. LG VX5500 Audio Port Replacement: adım 3, 3 resimden 1. LG VX5500 Audio Port Replacement: adım 3, 3 resimden 2. LG VX5500 Audio Port Replacement: adım 3, 3 resimden 3.
    • Carefully pry off the phone's backing using a plastic opening tool.
    • Slip the tool into the crack between the keypad (front panel) and the back panel.
    • Slide the tool along the sides of the phone to detach the tabs holding the backing on.
  4. LG VX5500 Audio Port Replacement: adım 4, 2 resimden 1. LG VX5500 Audio Port Replacement: adım 4, 2 resimden 2.
    • Locate the audio port; this is what it should look like.
    • The audio port is mounted and connected at 6 points. Check the integrity of these connections.
    • If any of the connections are dislodged or the audio port is damaged, desolder the port and install a new one.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kurt Beske
70 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 7-33, Maness Spring 2012 Cal Poly, Team 7-33, Maness Spring 2012 üyesi
CPSU-MANESS-S12S7G33
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 459
