Ana içeriğe geç
LG VX5500 Mother Board Replacement
Neye ihtiyacın var
  1. LG VX5500 Mother Board Replacement, Battery: adım 1, 3 resimden 1. LG VX5500 Mother Board Replacement, Battery: adım 1, 3 resimden 2. LG VX5500 Mother Board Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
    • Our device did not come with a battery cover so it is not shown here.
    • Remove the battery using your finger to pry it out of the battery housing.
  2. LG VX5500 Mother Board Replacement, Mother Board: adım 2, 2 resimden 1. LG VX5500 Mother Board Replacement, Mother Board: adım 2, 2 resimden 2.
    • Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack.
    • Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
  3. LG VX5500 Mother Board Replacement: adım 3, 3 resimden 1. LG VX5500 Mother Board Replacement: adım 3, 3 resimden 2. LG VX5500 Mother Board Replacement: adım 3, 3 resimden 3.
    • Carefully pry off the phone's backing using a plastic opening tool.
    • Slip the tool into the crack between the keypad (front panel) and the back panel.
    • Slide the tool along the sides of the phone to detach the tabs holding the backing on.
  4. LG VX5500 Mother Board Replacement: adım 4, 2 resimden 1. LG VX5500 Mother Board Replacement: adım 4, 2 resimden 2.
    • Peel back the sticker with tweezers and hold it back with your finger.
    • Use the tweezers to lift the display adapter off the logic board.
  5. LG VX5500 Mother Board Replacement: adım 5, 2 resimden 1. LG VX5500 Mother Board Replacement: adım 5, 2 resimden 2.
    • Lift the mother board out of the phone casing.
    • The keyboard can be easily removed once the mother board is out of the phone.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Henry
181 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-33, Maness Spring 2012 Cal Poly, Team 7-33, Maness Spring 2012 üyesi
CPSU-MANESS-S12S7G33
4 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
You guys are great!
Kurt Beske - Yanıt
So what do you do with the mother board then?
Erik Sodders - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 2,123
