Ana içeriğe geç
LG VX5500 Screen Replacement
Neye ihtiyacın var
  1. LG VX5500 Screen Replacement, Battery: adım 1, 3 resimden 1. LG VX5500 Screen Replacement, Battery: adım 1, 3 resimden 2. LG VX5500 Screen Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
    • Our device did not come with a battery cover so it is not shown here.
    • Remove the battery using your finger to pry it out of the battery housing.
  2. LG VX5500 Screen Replacement, Screen: adım 2, 2 resimden 1. LG VX5500 Screen Replacement, Screen: adım 2, 2 resimden 2.
    • Carefully pry off the black plastic screen cover using the iSesamo tool or another thin, flat tool.
    • The screen cover is adhered to the phone and may take some effort to pry off. If it is too difficult to remove, heat the screen with a hair dryer on low for 30 seconds to soften the adhesive.
  3. LG VX5500 Screen Replacement: adım 3, 2 resimden 1. LG VX5500 Screen Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Unscrew the (4) 3.6mm screws near each corner of the phone's display panel by using a #00 Phillips head screwdriver.
    • The bottom two screws may have small rubber covers that you can remove using tweezers.
  4. LG VX5500 Screen Replacement: adım 4, 3 resimden 1. LG VX5500 Screen Replacement: adım 4, 3 resimden 2. LG VX5500 Screen Replacement: adım 4, 3 resimden 3.
    • Pry off the front panel of the phone using a Plastic Opening Tool.
    • Push the tool into the crack along the side of the phone.
    • Slide the tool along the crack to detach the tabs holding the backing on the phone.
  5. LG VX5500 Screen Replacement: adım 5, 2 resimden 1. LG VX5500 Screen Replacement: adım 5, 2 resimden 2.
    • Use the tweezers to lift the display adapter off the screen component.
  6. LG VX5500 Screen Replacement: adım 6, 2 resimden 1. LG VX5500 Screen Replacement: adım 6, 2 resimden 2.
    • Using tweezers remove the speaker from its casing.
    • The speaker is adhered to the phone casing so it will take a small amount of force to remove it.
  7. LG VX5500 Screen Replacement: adım 7, 2 resimden 1. LG VX5500 Screen Replacement: adım 7, 2 resimden 2.
    • Remove the earpiece by lifting it out of the phone casing using tweezers.
    • The earpiece is adhered to the phone casing so it will take a small amount of force to remove it.
  8. LG VX5500 Screen Replacement: adım 8, 2 resimden 1. LG VX5500 Screen Replacement: adım 8, 2 resimden 2.
    • Remove the vibration motor by lifting it out of the phone casing using tweezers.
    • The motor is adhered to the phone casing so it will take a small amount of force to remove it.
  9. LG VX5500 Screen Replacement: adım 9, 1 resimden 1.
    • Lift the screen components out of the phone.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Henry
181 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-33, Maness Spring 2012 Cal Poly, Team 7-33, Maness Spring 2012 üyesi
CPSU-MANESS-S12S7G33
4 Üyeler
10 adet Kılavuz yazıldı
2Kılavuz Yorumları
I have it apart know need to learn to solder!
Andy Fowler - Yanıt
where can i purchase a replacement screen?
kalea dean - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 28
Her zaman: 3,887
