Giriş
The screens for the LG VX5600 come together as a single unit inside the phone therefore to replace one you will be replacing the other.
Neye ihtiyacın var
Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
Bu adımda kullanılan alet:Tweezers$4.99
Use tweezers to remove the two rubber covers found at the left and right corners below the inside screen.
Use one hand to grasp the phone and prop the inner grey casing up.
Unscrew the two 3.0-mm Phillips #000 screws located in the upper left and right hand corners.
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
just swapped screens Perfect. step 5 is harder than it look but take time and go easy, I used a 1/8 in blade screwdriver.
