Ana içeriğe geç
LG VX6000 Logic Board Replacement
Neye ihtiyacın var
  1. LG VX6000 Logic Board Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the dark gray tab on the back of the phone.
    • Push the tab towards the top of the phone to release the battery.
  2. LG VX6000 Logic Board Replacement: adım 2, 1 resimden 1.
    • Lift and rotate the battery away from the bottom edge.
    • Remove the battery.
  3. LG VX6000 Logic Board Replacement, Body: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Carefully use tweezers to remove the two rubber cushions located at the top of the phone.
    • Only remove the two cushions that are circled!
  4. LG VX6000 Logic Board Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the six screws highlighted on the back of the phone.
    • Place the screws on an uncluttered surface or in a small container.
  5. LG VX6000 Logic Board Replacement: adım 5, 1 resimden 1.
    • Carefully remove the back of the phone with your fingernails or tweezers.
    • There are red and blue wires connected to the motherboard. Forcing the components apart could damage the wires.
    • The red and blue wires must be plugged in to reassemble.
  6. LG VX6000 Logic Board Replacement, Logic Board: adım 6, 1 resimden 1.
    • Carefully peel away the adhesive tab.
    • The tab should not be completely separated from the phone.
  7. LG VX6000 Logic Board Replacement: adım 7, 2 resimden 1. LG VX6000 Logic Board Replacement: adım 7, 2 resimden 2.
    • Locate the yellow connection towards the top of the phone. This is directly connected to the screen.
    • Carefully pry the connector away from the motherboard to remove it from the phone.
    • Do not pull forcefully
  8. LG VX6000 Logic Board Replacement: adım 8, 1 resimden 1.
    • Gently lift the corner of the motherboard away from the casing.
Sonuç
Adam Altman
1 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-11, Forte Winter 2010 Cal Poly, Team 4-11, Forte Winter 2010 üyesi
CPSU-FORTE-W10S4G11
5 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 3,189
