Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Locate the dark gray tab on the back of the phone towards the top. Push the tab towards the top of the phone to release the battery.
Bu adımda kullanılan alet:Tweezers$4.99-
Pull out the two rubber cushions located on the top of the phone using tweezers.
Unscrew the six screws seen on the back using a Phillips 00 Screwdriver.
Remove screws and carefully place on an uncluttered surface or in a small container.
Carefully remove the back of the phone gently using your fingernails or tweezers.
Carefully peel off the adhesive tab as shown in the photo
Locate the yellow connection towards the top of the phone. This is directly connected to the screen.
Remove the connector by carefully prying it away from the motherboard and lifting it away from the phone
Gently lift a corner of the motherboard away from the casing to remove.
