Ana içeriğe geç
LG VX6000 Screen Replacement
Neye ihtiyacın var
    1. LG VX6000 Screen Replacement, Battery: adım 1, 1 resimden 1.
      • Locate the dark gray tab on the back of the phone.
      • Push the tab towards the top of the phone to release the battery.
      FixBot'a Sor
      Yorum Ekle
    2. LG VX6000 Screen Replacement: adım 2, 1 resimden 1.
      • Lift and rotate the battery away from the bottom edge.
      • Remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. LG VX6000 Screen Replacement, Body: adım 3, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Carefully use tweezers to remove the two rubber cushions located at the top of the phone.
      • Only remove the two cushions that are circled!
      FixBot'a Sor
      Yorum Ekle
    2. LG VX6000 Screen Replacement: adım 4, 1 resimden 1.
      • Use a Phillips #00 screwdriver to remove the six screws highlighted on the back of the phone.
      • Place the screws on an uncluttered surface or in a small container.
      FixBot'a Sor
      Yorum Ekle
    3. LG VX6000 Screen Replacement: adım 5, 1 resimden 1.
      • Carefully remove the back of the phone with your fingernails or tweezers.
      • There are red and blue wires connected to the motherboard. Forcing the components apart could damage the wires.
      • The red and blue wires must be plugged in to reassemble.
      FixBot'a Sor
      Yorum Ekle
    1. LG VX6000 Screen Replacement, Logic Board: adım 6, 1 resimden 1.
      • Carefully peel away the adhesive tab.
      • The tab should not be completely separated from the phone.
      FixBot'a Sor
      Yorum Ekle
    2. LG VX6000 Screen Replacement: adım 7, 2 resimden 1. LG VX6000 Screen Replacement: adım 7, 2 resimden 2.
      • Locate the yellow connection towards the top of the phone. This is directly connected to the screen.
      • Carefully pry the connector away from the motherboard to remove it from the phone.
      • Do not pull forcefully
      FixBot'a Sor
      Yorum Ekle
    3. LG VX6000 Screen Replacement: adım 8, 1 resimden 1.
      • Gently lift the corner of the motherboard away from the casing.
      FixBot'a Sor
      Yorum Ekle
    1. LG VX6000 Screen Replacement, Screen: adım 9, 3 resimden 1. LG VX6000 Screen Replacement, Screen: adım 9, 3 resimden 2. LG VX6000 Screen Replacement, Screen: adım 9, 3 resimden 3.
      • Using a paper clip or tweezers, pop out the screen by pressing the plastic tab in the top-left corner of the phone's bottom casing as indicated in the photo.
      • Be careful not to lose the tab that pops out. It is a small and clear piece of plastic.
      • The tab is fragile, handle with care.
      FixBot'a Sor
      Yorum Ekle
    2. LG VX6000 Screen Replacement: adım 10, 3 resimden 1. LG VX6000 Screen Replacement: adım 10, 3 resimden 2. LG VX6000 Screen Replacement: adım 10, 3 resimden 3.
      • As shown in the photos, pull the orange strip through a thin opening at the top of the phone. Once this is done, the top and bottom halves can be separated.
      FixBot'a Sor
      Yorum Ekle
    3. LG VX6000 Screen Replacement: adım 11, 1 resimden 1.
      • Set the bottom half of the phone aside.
      • Using tweezers, pull off the small rubber cushions located towards the four corners of the screen.
      FixBot'a Sor
      Yorum Ekle
    4. LG VX6000 Screen Replacement: adım 12, 1 resimden 1.
      • With a Phillips tip screwdriver, unscrew the four newly exposed screws.
      • Keep screws from the different steps in different locations so as to not mix them up.
      FixBot'a Sor
      Yorum Ekle
    5. LG VX6000 Screen Replacement: adım 13, 3 resimden 1. LG VX6000 Screen Replacement: adım 13, 3 resimden 2. LG VX6000 Screen Replacement: adım 13, 3 resimden 3.
      • Carefully open the casing using the iFixit plastic tool by prying each side a little bit at a time. Rotate and open until all the inside clips pop open and the casing opens up.
      FixBot'a Sor
      Yorum Ekle
    6. LG VX6000 Screen Replacement: adım 14, 2 resimden 1. LG VX6000 Screen Replacement: adım 14, 2 resimden 2.
      • After you pry open the casing, you will be left with the screen and circuit board in the top face plate.
      • Gently pull the corner of screen and circuit board up and out of casing to remove screen from the top face plate.
      • Do not try to completely separate the circuit board from the casing. There are still wires connecting the two.
      FixBot'a Sor
      Yorum Ekle
    7. LG VX6000 Screen Replacement: adım 15, 1 resimden 1.
      • Rotate the screen and the connected white frame away from the logic board.
      • Carefully peel the adhesive tape that connects the screen and logic board off. The screen can now be removed and replaced with a new screen unit.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Adam Altman
1 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-11, Forte Winter 2010 Cal Poly, Team 4-11, Forte Winter 2010 üyesi
CPSU-FORTE-W10S4G11
5 Üyeler
60 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 36
Her zaman: 3,196
