Ana içeriğe geç
LG VX6100 Back Cover Replacement
Neye ihtiyacın var
  1. LG VX6100 Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • Push down on the gray "PUSH" button on the back side of the phone.
    • Slide the back case downward. Then, lift and remove the case.
  2. LG VX6100 Back Cover Replacement: adım 2, 1 resimden 1.
    • Lift up on the battery to remove it from the case.
  3. LG VX6100 Back Cover Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a push-pin or tweezers to pry both of the tear-shaped screw covers out of the top of the phone.
  4. LG VX6100 Back Cover Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to unscrew the six case screws from the back of the phone.
  5. LG VX6100 Back Cover Replacement: adım 5, 2 resimden 1. LG VX6100 Back Cover Replacement: adım 5, 2 resimden 2.
    • Insert a plastic opener tool through the seam between the back case and the rest of the phone.
    • Slowly slide the tool along the seam. Lift up on the back case while you do this until the back case comes apart.
Sonuç
Teal
1 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-39, Regan Spring 2012 Cal Poly, Team 12-39, Regan Spring 2012 üyesi
CPSU-REGAN-S12S12G39
3 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 17
Her zaman: 604
