Ana içeriğe geç
LG VX6100 Speaker Replacement
Neye ihtiyacın var
    1. LG VX6100 Speaker Replacement, Front Case: adım 1, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Remove the four grey plugs using either tweezers or a push pin.
      FixBot'a Sor
      Yorum Ekle
    2. LG VX6100 Speaker Replacement: adım 2, 1 resimden 1.
      • Remove the four screws that are now exposed using a Phillips #00 screwdriver.
      • Be sure to put the screws in a safe place as they are very small and easy to lose.
      FixBot'a Sor
      Yorum Ekle
    3. LG VX6100 Speaker Replacement: adım 3, 1 resimden 1.
      • Once all the screws have been removed, use a plastic opener tool to pry the case from the rest of the phone.
      • Insert the opener tool into the seem between the case and the phone. Apply pressure to separate the two pieces.
      • Do this across the entire length of the seem until the case is no longer attached to the phone.
      FixBot'a Sor
      Yorum Ekle
    4. LG VX6100 Speaker Replacement: adım 4, 1 resimden 1.
      • The case can now be removed and the interior of the front is accessible.
      FixBot'a Sor
      Yorum Ekle
    1. LG VX6100 Speaker Replacement, Speaker: adım 5, 2 resimden 1. LG VX6100 Speaker Replacement, Speaker: adım 5, 2 resimden 2.
      • Locate the four solder joints (connected to the yellow, black, blue, and red wires) on the bottom part of the phone, connected to the speaker. It will appear as a black circular part with some holes in it.
      • Place a piece of solder wick on top of the solders.
      • Very carefully, place the tip of the soldering iron on top of the solder wick. Hold it steady until the solder is soaked up into the solder wick.
      • Soldering iron will damage circuitry if held down for too long.
      • Cut off the used solder wick with pliers and repeat this step if any solder remains.
      FixBot'a Sor
      Yorum Ekle
    2. LG VX6100 Speaker Replacement: adım 6, 1 resimden 1.
      • After the solder has been removed, pry out the speaker with the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Ryan Bishop
1 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-39, Regan Spring 2012 Cal Poly, Team 12-39, Regan Spring 2012 üyesi
CPSU-REGAN-S12S12G39
3 Üyeler
80 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 37
Her zaman: 917
