Ana içeriğe geç
LG VX7000 Charger Adapter Replacement
Neye ihtiyacın var
  1. LG VX7000 Charger Adapter Replacement, Battery: adım 1, 1 resimden 1.
    • Lay the phone, screen side down, in your palm.
    • Slide the grey button towards the top of the phone.
  2. LG VX7000 Charger Adapter Replacement: adım 2, 1 resimden 1.
    • With the button unlocked, grab the battery on the sides and pull up, then slide the battery up to completely remove it from the phone.
  3. LG VX7000 Charger Adapter Replacement, Motherboard: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use the Phillips #00 and remove the four screws on the lower backside of the phone.
    • Remove the three rubber screw covers with tweezers and then the three screws underneath using a Phillips #00 screwdriver.
  4. LG VX7000 Charger Adapter Replacement: adım 4, 1 resimden 1.
    • Detach the outer casing from the back of the phone.
    • There will be a significant amount of resistance to detaching the back casing.
  5. LG VX7000 Charger Adapter Replacement: adım 5, 1 resimden 1.
    • Unsnap the gold rectangular connector and silver square connector from the motherboard.
  6. LG VX7000 Charger Adapter Replacement: adım 6, 1 resimden 1.
    • Remove the motherboard. Do not remove other components.
    • Insert the new motherboard with the white side facing down.
    • Make sure the side buttons on motherboard are correctly aligned to avoid future complications.
  7. LG VX7000 Charger Adapter Replacement, Charger Adapter: adım 7, 1 resimden 1.
    • Replace logic board to replace charging adapter.
Sonuç
Nichole Shaw
1 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-75, Johann Spring 2010 Cal Poly, Team 18-75, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S18G75
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 18
Her zaman: 2,549
