Giriş
Sat on your phone and cracked the outer screen? Then here is the guide on how to replace it.
NOTE: Replacing the outer screen requires replacing the entire outer casing.
Neye ihtiyacın var
Bu adımda kullanılan alet:Tweezers$4.99
Using a pair of tweezers, remove the rubber screw covers located at each corner of the main screen.
Turn the screwdriver counterclockwise to unscrew the screws located under the recently removed rubber plugs.
Neredeyse bitti!
Sonuç
