Ana içeriğe geç
LG VX7000 Internal LCD Screen Replacement
Neye ihtiyacın var
  1. LG VX7000 Internal LCD Screen Replacement, Internal LCD Screen: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using Tweezers, remove 4 rubber screw covers.
    • Remove screws located under rubber plugs using the screwdriver by turning counterclockwise.
    • NOTE: Screws will not come completely out of phone.
  2. LG VX7000 Internal LCD Screen Replacement: adım 2, 1 resimden 1.
    • Using the iPod Opening Tool, pry the face plate off the front of the phone.
    • NOTE: There will be a significant amount of resistance to removing the face plate from the phone.
  3. LG VX7000 Internal LCD Screen Replacement: adım 3, 1 resimden 1.
    • Unsnap gold plate from the secondary logic board.
    • Reposition the plate so that it is out of the way for face plate removal.
  4. LG VX7000 Internal LCD Screen Replacement: adım 4, 1 resimden 1.
    • Twist upper half of face plate in order to release it from the hinge.
    • Using tweezers detach the speaker and the secondary battery from the faceplate, leaving wires attached.
  5. LG VX7000 Internal LCD Screen Replacement: adım 5, 1 resimden 1.
    • Align new face plate in correct orientation in order to install.
Sonuç
Nichole Shaw
1 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-75, Johann Spring 2010 Cal Poly, Team 18-75, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S18G75
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 17
Her zaman: 2,265
