Ana içeriğe geç
LG VX8550 Camera Replacement
Neye ihtiyacın var
  1. LG VX8550 Camera Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the battery release up.
    FixBot'a Sor
  2. LG VX8550 Camera Replacement: adım 2, 1 resimden 1.
    • Remove the battery by lifting away from the case.
    FixBot'a Sor
  3. LG VX8550 Camera Replacement, Case: adım 3, 1 resimden 1.
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
    FixBot'a Sor
  4. LG VX8550 Camera Replacement: adım 4, 1 resimden 1.
    • Remove the 4 cover screws with a Philips #00 screwdriver.
    FixBot'a Sor
  5. LG VX8550 Camera Replacement: adım 5, 1 resimden 1.
    • Use the iPod opening tool to pry off the back casing.
    FixBot'a Sor
  6. LG VX8550 Camera Replacement: adım 6, 1 resimden 1.
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
    FixBot'a Sor
  7. LG VX8550 Camera Replacement: adım 7, 1 resimden 1.
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
    FixBot'a Sor
  8. LG VX8550 Camera Replacement, Motherboard: adım 8, 1 resimden 1.
    • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
    FixBot'a Sor
  9. LG VX8550 Camera Replacement: adım 9, 1 resimden 1.
    • Carefully lift up on the motherboard to see the ribbon cables underneath.
    • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
    FixBot'a Sor
  10. LG VX8550 Camera Replacement: adım 10, 1 resimden 1.
    • Remove the motherboard from the front casing by lifting straight up.
    FixBot'a Sor
  11. LG VX8550 Camera Replacement, Keypad Housing: adım 11, 1 resimden 1.
    • Lay the phone with the screen facedown.
    • The 6 slider screws are visible.
    FixBot'a Sor
  12. LG VX8550 Camera Replacement: adım 12, 1 resimden 1.
    • Peel back but don't remove the blue tape to access the 2 center screws.
    • Remove the 6 slider screws with the Phillips #00 screwdriver.
    FixBot'a Sor
  13. LG VX8550 Camera Replacement: adım 13, 1 resimden 1.
    • Lift the keypad housing away from the slider.
    FixBot'a Sor
  14. LG VX8550 Camera Replacement, Front Case: adım 14, 1 resimden 1.
    • Remove the 2 screw covers next to the speaker with a push pin next to the camera.
    FixBot'a Sor
  15. LG VX8550 Camera Replacement: adım 15, 1 resimden 1.
    • Remove the 6 screws with a Phillips #00 Screwdriver.
    FixBot'a Sor
  16. LG VX8550 Camera Replacement: adım 16, 1 resimden 1.
    • Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
    FixBot'a Sor
  17. LG VX8550 Camera Replacement: adım 17, 1 resimden 1.
    • Carefully lift the slider mechanism to see the ribbon cables underneath.
    FixBot'a Sor
  18. LG VX8550 Camera Replacement: adım 18, 1 resimden 1.
    • Slide ribbon cable through the slider mechanism.
    FixBot'a Sor
  19. LG VX8550 Camera Replacement: adım 19, 1 resimden 1.
    • Separate the two halves.
    FixBot'a Sor
  20. LG VX8550 Camera Replacement, Camera: adım 20, 1 resimden 1.
    • With the screen casing separated from the slider mechanism the camera circuit board is visible.
    • Carefully lift up on the connector to unplug it from the circuit board.
    FixBot'a Sor
  21. LG VX8550 Camera Replacement: adım 21, 1 resimden 1.
    • Lift up slowly on the connector cable to peel the camera off the adhesive backing.
    FixBot'a Sor
  22. LG VX8550 Camera Replacement: adım 22, 1 resimden 1.
    • Remove camera from the casing.
    FixBot'a Sor
Sonuç
Nathan Jones
89 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 34-55, Forte Spring 2010 Cal Poly, Team 34-55, Forte Spring 2010 üyesi
CPSU-FORTE-S10S34G55
5 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 72
Her zaman: 1,675
