Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the 2 screw covers next to the rear speaker with a Push Pin.
Remove the 4 cover screws with a Philips #00 screwdriver.
Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
Carefully lift up on the motherboard to see the ribbon cables underneath.
Use the spudger to carefully disconnect the ribbon cable from the motherboard.
Remove the motherboard from the front casing by lifting straight up.
Bir Yorum
It is a nice way to remove the motherboard of the LG mobile i did not done it but your have done it very nicely and with a great way. thanks for this good post i really enjoy the reading.
