Ana içeriğe geç
LG VX8550 Screen Replacement
Neye ihtiyacın var
  1. LG VX8550 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the battery release up.
  2. LG VX8550 Screen Replacement: adım 2, 1 resimden 1.
    • Remove the battery by lifting away from the case.
  3. LG VX8550 Screen Replacement, Case: adım 3, 1 resimden 1.
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. LG VX8550 Screen Replacement: adım 4, 1 resimden 1.
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. LG VX8550 Screen Replacement: adım 5, 1 resimden 1.
    • Use the iPod opening tool to pry off the back casing.
  6. LG VX8550 Screen Replacement: adım 6, 1 resimden 1.
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. LG VX8550 Screen Replacement: adım 7, 1 resimden 1.
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  8. LG VX8550 Screen Replacement, Motherboard: adım 8, 1 resimden 1.
    • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
  9. LG VX8550 Screen Replacement: adım 9, 1 resimden 1.
    • Carefully lift up on the motherboard to see the ribbon cables underneath.
    • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
  10. LG VX8550 Screen Replacement: adım 10, 1 resimden 1.
    • Remove the motherboard from the front casing by lifting straight up.
  11. LG VX8550 Screen Replacement, Keypad Housing: adım 11, 1 resimden 1.
    • Lay the phone with the screen facedown.
    • The 6 slider screws are visible.
  12. LG VX8550 Screen Replacement: adım 12, 1 resimden 1.
    • Peel back but don't remove the blue tape to access the 2 center screws.
    • Remove the 6 slider screws with the Phillips #00 screwdriver.
  13. LG VX8550 Screen Replacement: adım 13, 1 resimden 1.
    • Lift the keypad housing away from the slider.
  14. LG VX8550 Screen Replacement, Front Case: adım 14, 1 resimden 1.
    • Remove the 2 screw covers next to the speaker with a push pin next to the camera.
  15. LG VX8550 Screen Replacement: adım 15, 1 resimden 1.
    • Remove the 6 screws with a Phillips #00 Screwdriver.
  16. LG VX8550 Screen Replacement: adım 16, 1 resimden 1.
    • Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
  17. LG VX8550 Screen Replacement: adım 17, 1 resimden 1.
    • Carefully lift the slider mechanism to see the ribbon cables underneath.
  18. LG VX8550 Screen Replacement: adım 18, 1 resimden 1.
    • Slide ribbon cable through the slider mechanism.
  19. LG VX8550 Screen Replacement: adım 19, 1 resimden 1.
    • Separate the two halves.
  20. LG VX8550 Screen Replacement, Screen: adım 20, 1 resimden 1.
    • With the spudger, lift up under the connector to unplug it from the circuit board.
  21. LG VX8550 Screen Replacement: adım 21, 1 resimden 1.
    • Lift and remove the blue tape from screen connector.
  22. LG VX8550 Screen Replacement: adım 22, 1 resimden 1.
    • Lift the top edge of the screen using a pin to pry under the corner.
  23. LG VX8550 Screen Replacement: adım 23, 1 resimden 1.
    • Grasp the ribbon cable near the connector and carefully slide it out of the white connector.
    • It is helpful to gently wiggle the ribbon cable from side to side.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nathan Jones
89 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 34-55, Forte Spring 2010 Cal Poly, Team 34-55, Forte Spring 2010 üyesi
CPSU-FORTE-S10S34G55
5 Üyeler
22 adet Kılavuz yazıldı
1Rehber Yorum
What’s the process if I just need to replace the flex cable not the whole screen?
Roll Sumthin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 22
Her zaman: 4,067
