Ana içeriğe geç
LG VX8550 Speaker Replacement
Neye ihtiyacın var
  1. LG VX8550 Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the battery release up.
  2. LG VX8550 Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the battery by lifting away from the case.
  3. LG VX8550 Speaker Replacement, Case: adım 3, 1 resimden 1.
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. LG VX8550 Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. LG VX8550 Speaker Replacement: adım 5, 1 resimden 1.
    • Use the iPod opening tool to pry off the back casing.
  6. LG VX8550 Speaker Replacement: adım 6, 1 resimden 1.
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. LG VX8550 Speaker Replacement: adım 7, 1 resimden 1.
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  8. LG VX8550 Speaker Replacement, Speaker: adım 8, 1 resimden 1.
    • With the back casing removed the speaker is visible.
  9. LG VX8550 Speaker Replacement: adım 9, 1 resimden 1.
    • Lift up under top end of circuit board with the Spludger to access retaining clip.
  10. LG VX8550 Speaker Replacement: adım 10, 1 resimden 1.
    • Carefully pry up on retaining clip with the Spudger to release the speaker.
  11. LG VX8550 Speaker Replacement: adım 11, 1 resimden 1.
    • Carefully unplug speaker connector from circuit board with your fingers.
  12. LG VX8550 Speaker Replacement: adım 12, 1 resimden 1.
    • Remove the speaker by lifting up.
Sonuç
Nathan Jones
89 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 34-55, Forte Spring 2010 Cal Poly, Team 34-55, Forte Spring 2010 üyesi
CPSU-FORTE-S10S34G55
5 Üyeler
20 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 2,003
