Ana içeriğe geç
LG VX8560 Keypad Replacement
Neye ihtiyacın var
  1. LG VX8560 Keypad Replacement, Keypad: adım 1, 2 resimden 1. LG VX8560 Keypad Replacement, Keypad: adım 1, 2 resimden 2.
    • Remove the battery by sliding the battery cover off the phone.
    • Unscrew all 4 screws along the edge of the phone using the Philips #00 Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. LG VX8560 Keypad Replacement: adım 2, 2 resimden 1. LG VX8560 Keypad Replacement: adım 2, 2 resimden 2.
    • Insert the iFixit Opening Tool between the phone’s keypad cover and the back cover, and gently pull apart.
    • Be careful with the motherboard; don’t let it detach.
    FixBot'a Sor
    Yorum Ekle
  3. LG VX8560 Keypad Replacement: adım 3, 1 resimden 1.
    • Insert the new keypad into the cover frame and check the dimensions.
    FixBot'a Sor
    Yorum Ekle
  4. LG VX8560 Keypad Replacement: adım 4, 2 resimden 1. LG VX8560 Keypad Replacement: adım 4, 2 resimden 2.
    • Gently snap the cover frame back to the right position.
    • Replace the screws using the Phillips #00 Screwdriver.
    • Insert the battery and snap the back cover on.
    FixBot'a Sor
    Yorum Ekle
Sonuç
The keypad is successfully replaced.
Bir başkası bu kılavuzu tamamladı.
Jack Foley
37 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-62, Johann Spring 2013 Cal Poly, Team 13-62, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S13G62
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 31
Her zaman: 572
