Ana içeriğe geç
LG VX8560 Side Key Replacement
Neye ihtiyacın var
    1. LG VX8560 Side Key Replacement, Battery: adım 1, 1 resimden 1.
      • Turn the phone over so that the backside is facing up.
      FixBot'a Sor
      Yorum Ekle
    2. LG VX8560 Side Key Replacement: adım 2, 1 resimden 1.
      • Push the battery cover from the indentation and slide it away from the phone to remove it.
      FixBot'a Sor
      Yorum Ekle
    3. LG VX8560 Side Key Replacement: adım 3, 2 resimden 1. LG VX8560 Side Key Replacement: adım 3, 2 resimden 2.
      • Remove the battery from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. LG VX8560 Side Key Replacement, Side Keys: adım 4, 2 resimden 1. LG VX8560 Side Key Replacement, Side Keys: adım 4, 2 resimden 2.
      • Using a Phillips #00 screwdriver, remove all four screws that are visible along the edge of the phone
      FixBot'a Sor
      Yorum Ekle
    2. LG VX8560 Side Key Replacement: adım 5, 3 resimden 1. LG VX8560 Side Key Replacement: adım 5, 3 resimden 2. LG VX8560 Side Key Replacement: adım 5, 3 resimden 3.
      • Find the seam between the phone’s keypad cover and back cover, and slide a plastic pry tool along the edge to gently pry the two pieces apart without completely separating them.
      • The motherboard should be visible. Do not separate the two covers. They should be held together by a screw at the axis of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. LG VX8560 Side Key Replacement: adım 6, 2 resimden 1. LG VX8560 Side Key Replacement: adım 6, 2 resimden 2.
      • Place the side keys so that they are aligned with the silver circles located on the side of the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevin
7 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-62, Johann Spring 2013 Cal Poly, Team 13-62, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S13G62
4 Üyeler
60 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 22
Her zaman: 540
