Ana içeriğe geç
LG VX8560 Side Key Replacement
Neye ihtiyacın var
  1. LG VX8560 Side Key Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the phone over so its backside is facing up
  2. LG VX8560 Side Key Replacement: adım 2, 1 resimden 1.
    • Push the battery cover from the indentation and slide the battery cover away from phone to remove battery cover
  3. LG VX8560 Side Key Replacement: adım 3, 2 resimden 1. LG VX8560 Side Key Replacement: adım 3, 2 resimden 2.
    • Remove the battery from the phone
  4. LG VX8560 Side Key Replacement, Side Keys: adım 4, 2 resimden 1. LG VX8560 Side Key Replacement, Side Keys: adım 4, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove all four screws that are visible along the edge of the phone
  5. LG VX8560 Side Key Replacement: adım 5, 3 resimden 1. LG VX8560 Side Key Replacement: adım 5, 3 resimden 2. LG VX8560 Side Key Replacement: adım 5, 3 resimden 3.
    • Find the seam between the phone’s keypad cover and back cover, and slide a plastic pry tool along the edge to gently pry the two pieces apart without completely separating them.
    • The motherboard should be visible. Do not separate the two covers. They should be held together by a screw at the axis of the phone.
  6. LG VX8560 Side Key Replacement: adım 6, 2 resimden 1. LG VX8560 Side Key Replacement: adım 6, 2 resimden 2.
    • Place the side keys so that they are aligned with the silver circles located on the side of the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevin
7 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-62, Johann Spring 2013 Cal Poly, Team 13-62, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S13G62
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 21
Her zaman: 232
