Ana içeriğe geç
LG VX8700 Front Bezel Replacement
Neye ihtiyacın var
  1. LG VX8700 Front Bezel Replacement, Battery: adım 1, 2 resimden 1. LG VX8700 Front Bezel Replacement, Battery: adım 1, 2 resimden 2.
    • Power the phone off.
    • Slide the back cover off using the release latch with your fingers to expose the battery.
  2. LG VX8700 Front Bezel Replacement: adım 2, 2 resimden 1. LG VX8700 Front Bezel Replacement: adım 2, 2 resimden 2.
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, align the metal pins with those of the phone.
  3. LG VX8700 Front Bezel Replacement, Front Bezel: adım 3, 1 resimden 1.
    • Turn your phone around and open the flip phone. The screen is now facing you.
    • Locate the two grey rubber plugs on the bottom corners of the screen. These plugs cover up two screws.
    • Remove the two grey screw-covers.
  4. LG VX8700 Front Bezel Replacement: adım 4, 2 resimden 1. LG VX8700 Front Bezel Replacement: adım 4, 2 resimden 2.
    • Use the ejection tab at the top to remove the screen.
    • There is a gap between the case and the screen near the ear piece.
    • Insert the plastic opening tool in the gap and pry up the screen.
    • The plastic screen cover is glued onto the phone. It may be difficult to pry off.
  5. LG VX8700 Front Bezel Replacement: adım 5, 1 resimden 1.
    • Unscrew the four corners of the screen using 3.21mm screws to separate the top cover of the phone.
  6. LG VX8700 Front Bezel Replacement: adım 6, 2 resimden 1. LG VX8700 Front Bezel Replacement: adım 6, 2 resimden 2.
    • Turn your phone around. The battery side will be facing you.
    • Insert the plastic opening tool into the groove to remove the top cover of the phone.
    • Carefully open the cover.
Sonuç
Stanley Thomas
41 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-16, Maness Winter 2012 Cal Poly, Team 8-16, Maness Winter 2012 üyesi
CPSU-MANESS-W12S8G16
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 1,036
