Giriş
The guide outlines the steps necessary to replace the keypad on the LG VX8700. The keypad is used to to help direct actions on the phone.
Neye ihtiyacın var
Slide the back cover off using the release latch with your fingers to expose the battery.
Remove the nine 4 mm screws from the back cover with a Phillips #0 screwdriver.
1Rehber Yorum
When I separated the two halves a small brass piece came out and your instructions do not show nor mention what this is or where it goes. Not even a caution about it coming out upon separation of the halves. It appears to belong on one of the screw posts and because it is brass I believe it is supposed to complete a circuit.
