Ana içeriğe geç
LG VX8700 Motherboard Replacement
Neye ihtiyacın var
  1. LG VX8700 Motherboard Replacement, Battery: adım 1, 2 resimden 1. LG VX8700 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Power the phone off.
    • Slide the back cover off using the release latch with your fingers to expose the battery.
  2. LG VX8700 Motherboard Replacement: adım 2, 2 resimden 1. LG VX8700 Motherboard Replacement: adım 2, 2 resimden 2.
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, align the metal pins with those of the phone.
  3. LG VX8700 Motherboard Replacement, Keypad: adım 3, 2 resimden 1. LG VX8700 Motherboard Replacement, Keypad: adım 3, 2 resimden 2.
    • Remove the nine 4 mm screws from the back cover with a Phillips #0 screwdriver.
  4. LG VX8700 Motherboard Replacement: adım 4, 2 resimden 1. LG VX8700 Motherboard Replacement: adım 4, 2 resimden 2.
    • Insert the tip of the iFixit opening tool into the small notch on the side of the case.
    • Slide the opening tool along the seam and around the edge of the phone to separate the case.
  5. LG VX8700 Motherboard Replacement: adım 5, 1 resimden 1.
    • Separate the two halves of the phone.
    • The back of the phone, which houses the motherboard and keypad, is displayed on the left.
    • The plastic casing is displayed on the right.
  6. LG VX8700 Motherboard Replacement: adım 6, 3 resimden 1. LG VX8700 Motherboard Replacement: adım 6, 3 resimden 2. LG VX8700 Motherboard Replacement: adım 6, 3 resimden 3.
    • Hold the phone casing with one hand and the keypad assembly with the other.
    • Separate the phone casing from the keypad/motherboard.
  7. LG VX8700 Motherboard Replacement: adım 7, 2 resimden 1. LG VX8700 Motherboard Replacement: adım 7, 2 resimden 2.
    • Pull the two boards apart to separate the keypad from the motherboard.
  8. LG VX8700 Motherboard Replacement, Motherboard: adım 8, 1 resimden 1.
    • First, pull back the tape covering the connection between the motherboard and the ribbon cable.
    • Separate the connection, using the plastic opening tool.
  9. LG VX8700 Motherboard Replacement: adım 9, 2 resimden 1. LG VX8700 Motherboard Replacement: adım 9, 2 resimden 2.
    • After the connection is removed, the motherboard is successfully removed.
Sonuç
Stanley Thomas
41 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-16, Maness Winter 2012 Cal Poly, Team 8-16, Maness Winter 2012 üyesi
CPSU-MANESS-W12S8G16
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 1,341
