Ana içeriğe geç
LG VX9800 Front Keypad Replacement
Neye ihtiyacın var
  1. LG VX9800 Front Keypad Replacement, Front Keypad: adım 1, 1 resimden 1.
    • Remove the two triangular pads at the top of the two speakers.
    • These pads have adhesive to keep them situated, so you may want to use a fine-tipped object, such as a screwdriver or a pen, to remove them. It is easiest to place the fine-tipped object in the small indent in the corner of these pads.
  2. LG VX9800 Front Keypad Replacement: adım 2, 1 resimden 1.
    • Remove the two rubber cylinders from their shafts. These cover more screws.
    • This requires a little more effort, so you may need to "dig" them out.
  3. LG VX9800 Front Keypad Replacement: adım 3, 1 resimden 1.
    • Now remove the four screws.
    • The screws are small, so put them somewhere that you can easily keep track of them.
  4. LG VX9800 Front Keypad Replacement: adım 4, 1 resimden 1.
    • Starting on the side with red square, pry the faceplate upwards with the flat end of a spudger.
    • Continue to slide the flat edge along the seam of the faceplate.
    • You should hear popping or snapping noises as the faceplate is being removed.
  5. LG VX9800 Front Keypad Replacement: adım 5, 2 resimden 1. LG VX9800 Front Keypad Replacement: adım 5, 2 resimden 2.
    • The faceplate is attached by wires, so do not pull the faceplate very far away from the phone.
    • Lift the dislodged faceplate off the motherboard while being mindful of the wires still attached to it.
  6. LG VX9800 Front Keypad Replacement: adım 6, 3 resimden 1. LG VX9800 Front Keypad Replacement: adım 6, 3 resimden 2. LG VX9800 Front Keypad Replacement: adım 6, 3 resimden 3.
    • The faceplate is still attached through speakers that travel from the ear-piece to the motherboard.
    • Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate.
    • This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
  7. LG VX9800 Front Keypad Replacement: adım 7, 1 resimden 1.
    • The faceplate and keypad can now be completely removed from the phone.
Bitiş Çizgisi
Aaron Rowley
33 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-32, Maness Winter 2010 Cal Poly, Team 16-32, Maness Winter 2010 üyesi
CPSU-MANESS-W10S16G32
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 1,923
