Ana içeriğe geç
LG Volt Charger Port Replacement
Neye ihtiyacın var
    1. LG Volt Charger Port Replacement, Charger Port: adım 1, 3 resimden 1. LG Volt Charger Port Replacement, Charger Port: adım 1, 3 resimden 2. LG Volt Charger Port Replacement, Charger Port: adım 1, 3 resimden 3.
      • Pry back cover with finger in the crease.
      • Remove back casing.
      FixBot'a Sor
      Yorum Ekle
    2. LG Volt Charger Port Replacement: adım 2, 3 resimden 1. LG Volt Charger Port Replacement: adım 2, 3 resimden 2. LG Volt Charger Port Replacement: adım 2, 3 resimden 3.
      • With your finger, pry the battery out through the crease made for removal.
      FixBot'a Sor
      Yorum Ekle
    3. LG Volt Charger Port Replacement: adım 3, 3 resimden 1. LG Volt Charger Port Replacement: adım 3, 3 resimden 2. LG Volt Charger Port Replacement: adım 3, 3 resimden 3.
      • Remove all 11 (4mm) screws with the JIS #000 screwdriver
      • There are three screws on top, three above the battery, one next to the battery, one under the battery and three at the bottom of the phone.
      FixBot'a Sor
      Yorum Ekle
    4. LG Volt Charger Port Replacement: adım 4, 3 resimden 1. LG Volt Charger Port Replacement: adım 4, 3 resimden 2. LG Volt Charger Port Replacement: adım 4, 3 resimden 3.
      • Use the plastic opening tool to remove the back housing from the frame of the phone.
      FixBot'a Sor
      Yorum Ekle
    5. LG Volt Charger Port Replacement: adım 5, 1 resimden 1.
      • Lift copper tab located on the right side of the device.
      FixBot'a Sor
      Yorum Ekle
    6. LG Volt Charger Port Replacement: adım 6, 2 resimden 1. LG Volt Charger Port Replacement: adım 6, 2 resimden 2.
      • Use a JIS #000 screwdriver to remove the 1 screw (4mm) on right side under copper tab.
      • Use a JIS #000 screwdriver to remove the screw (4mm) on bottom left under battery tray.
      FixBot'a Sor
      Yorum Ekle
    7. LG Volt Charger Port Replacement: adım 7, 3 resimden 1. LG Volt Charger Port Replacement: adım 7, 3 resimden 2. LG Volt Charger Port Replacement: adım 7, 3 resimden 3.
      • Disconnect the white and black cables as indicated.
      • Lift indicated flap as shown.
      FixBot'a Sor
      Yorum Ekle
    8. LG Volt Charger Port Replacement: adım 8, 3 resimden 1. LG Volt Charger Port Replacement: adım 8, 3 resimden 2. LG Volt Charger Port Replacement: adım 8, 3 resimden 3.
      • Use the plastic opening tool to carefully lift the charger assembly from the phone.
      • Start from the copper tab and continue in a clockwise direction.
      • Once it is loose remove the assembly from the phone.
      FixBot'a Sor
      Yorum Ekle
    9. LG Volt Charger Port Replacement: adım 9, 1 resimden 1.
      • Put a new charging port in place of old charging port.
      • Follow steps 8 through 1 in that order for reassembly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Adrian Soldan
464 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G3, Cannon Fall 2017 USF Tampa, Team S3-G3, Cannon Fall 2017 üyesi
USFT-CANNON-F17S3G3
3 Üyeler
28 adet Kılavuz yazıldı
2Kılavuz Yorumları
Great guide with excellent pictures
George Brooks - Yanıt Paylaş
Hi, I replaced mine, but I don’t think it’s working - what voltages should be present on which pins (at the battery connection) when it’s plugged in?
scottlhertzoglion - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 29
Her zaman: 1,062
