Ana içeriğe geç
LG Volt Motherboard Replacement
Neye ihtiyacın var
  1. LG Volt Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. LG Volt Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. LG Volt Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Pry back cover with finger in the crease.
    • Remove back casing.
  2. LG Volt Motherboard Replacement: adım 2, 3 resimden 1. LG Volt Motherboard Replacement: adım 2, 3 resimden 2. LG Volt Motherboard Replacement: adım 2, 3 resimden 3.
    • With your finger, pry the battery out through the crease made for removal.
  3. LG Volt Motherboard Replacement: adım 3, 3 resimden 1. LG Volt Motherboard Replacement: adım 3, 3 resimden 2. LG Volt Motherboard Replacement: adım 3, 3 resimden 3.
    • Remove all 11 (4mm) screws with the JIS #000 screwdriver
    • There are three screws on top, three above the battery, one next to the battery, one under the battery and three at the bottom of the phone.
  4. LG Volt Motherboard Replacement: adım 4, 3 resimden 1. LG Volt Motherboard Replacement: adım 4, 3 resimden 2. LG Volt Motherboard Replacement: adım 4, 3 resimden 3.
    • Use the plastic opening tool to remove the back housing from the frame of the phone.
  5. LG Volt Motherboard Replacement: adım 5, 2 resimden 1. LG Volt Motherboard Replacement: adım 5, 2 resimden 2.
    • Carefully lift all the indicated tabs.
    • Carefully unplug the marked cables.
  6. LG Volt Motherboard Replacement: adım 6, 2 resimden 1. LG Volt Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove motherboard carefully.
  7. LG Volt Motherboard Replacement: adım 7, 1 resimden 1.
    • Put new motherboard in place of old motherboard.
    • Follow steps 6 through 1 in that order for reassembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Adrian Soldan
464 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G3, Cannon Fall 2017 USF Tampa, Team S3-G3, Cannon Fall 2017 üyesi
USFT-CANNON-F17S3G3
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 606
