Ana içeriğe geç
LG Voyager Micro SD Replacement
Neye ihtiyacın var
  1. LG Voyager Micro SD Replacement, Micro SD: adım 1, 1 resimden 1.
    • Turn the phone onto its side so the label micro SD is facing upside down.
    • Once on its side, lift the micro SD cover up and swivel it away from the opening.
  2. LG Voyager Micro SD Replacement: adım 2, 2 resimden 1. LG Voyager Micro SD Replacement: adım 2, 2 resimden 2.
    • The Micro SD card will appear as a thin plastic piece sticking out of the phone
    • Gently push down on the card, you should hear a click, and then it will "spring" back at you.
    • The card should be sticking out of the phone slightly once this is done.
    • Remove the card from the slot
Sonuç
Michelle
20 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-26, Amido Spring 2012 Cal Poly, Team 17-26, Amido Spring 2012 üyesi
CPSU-AMIDO-S12S17G26
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 390
