Ana içeriğe geç
LG Vu CU920 Motherboard Replacement
Neye ihtiyacın var
    1. LG Vu CU920 Motherboard Replacement, Battery: adım 1, 3 resimden 1. LG Vu CU920 Motherboard Replacement, Battery: adım 1, 3 resimden 2. LG Vu CU920 Motherboard Replacement, Battery: adım 1, 3 resimden 3.
      • Remove the back cover by firmly pressing against the indent on the back panel. Slide the cover downward and off the phone.
      FixBot'a Sor
      Yorum Ekle
    2. LG Vu CU920 Motherboard Replacement: adım 2, 2 resimden 1. LG Vu CU920 Motherboard Replacement: adım 2, 2 resimden 2.
      • Remove the battery by placing your fingernail or an opening tool at the bottom edge of the battery and lift it out.
      FixBot'a Sor
      Yorum Ekle
    1. LG Vu CU920 Motherboard Replacement, Motherboard: adım 3, 1 resimden 1.
      • Remove the two 3.5 mm screws above the battery port with a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. LG Vu CU920 Motherboard Replacement: adım 4, 2 resimden 1. LG Vu CU920 Motherboard Replacement: adım 4, 2 resimden 2.
      • Pull out the antenna to reveal a third screw.
      • Remove the 3.5 mm screw with a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. LG Vu CU920 Motherboard Replacement: adım 5, 3 resimden 1. LG Vu CU920 Motherboard Replacement: adım 5, 3 resimden 2. LG Vu CU920 Motherboard Replacement: adım 5, 3 resimden 3.
      • Using a plastic opening tool, gently pop up the plastic tab.
      • Use the plastic opening tool to pry up the edges of the plastic casing. You will then be able to slide it around the edge to dislodge it.
      FixBot'a Sor
      Yorum Ekle
    4. LG Vu CU920 Motherboard Replacement: adım 6, 2 resimden 1. LG Vu CU920 Motherboard Replacement: adım 6, 2 resimden 2.
      • Remove the plastic case to reveal the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. LG Vu CU920 Motherboard Replacement: adım 7, 1 resimden 1.
      • Use a spudger to disconnect the cables from the motherboard.
      • The following steps will detail how to detach the cables from the connectors.
      FixBot'a Sor
      Yorum Ekle
    6. LG Vu CU920 Motherboard Replacement: adım 8, 3 resimden 1. LG Vu CU920 Motherboard Replacement: adım 8, 3 resimden 2. LG Vu CU920 Motherboard Replacement: adım 8, 3 resimden 3.
      • Gently lift the ZIF connector (black tab) holding the ribbon cable in place. When it is in the upright position, remove the cable from the back side.
      FixBot'a Sor
      Yorum Ekle
    7. LG Vu CU920 Motherboard Replacement: adım 9, 1 resimden 1.
      • Remove the jack attached to the red and blue wires by carefully pulling it upward from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    8. LG Vu CU920 Motherboard Replacement: adım 10, 1 resimden 1.
      • Remove the round jack connected to the black cabel by carefully prying it up from beneath with a spudger or plastic opening tool.
      • This jack snaps on, so there will be more resistance than there was with the previous jack.
      FixBot'a Sor
      Yorum Ekle
    9. LG Vu CU920 Motherboard Replacement: adım 11, 2 resimden 1. LG Vu CU920 Motherboard Replacement: adım 11, 2 resimden 2.
      • Remove the remaining three ribbon cables by gently lifting them by the ends, opposite of the cables, with a plastic opening tool or spudger until they pop out.
      FixBot'a Sor
      Yorum Ekle
    10. LG Vu CU920 Motherboard Replacement: adım 12, 3 resimden 1. LG Vu CU920 Motherboard Replacement: adım 12, 3 resimden 2. LG Vu CU920 Motherboard Replacement: adım 12, 3 resimden 3.
      • Remove the motherboard by gently prying it up with a spudger from the charging port.
      • Be careful not to yank the camera's ribbon cable as you lift the board. Make sure that it is in line with its hole in the motherboard.
      • Once the board has been lifted, remove it by pulling it away from the connected edge.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Gregory Davis
51 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-57, Johann Spring 2013 Cal Poly, Team 8-57, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S8G57
4 Üyeler
70 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 17
Her zaman: 762
